![]() | Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2780
Low voltage and low current is due to inadequate gauge wiring and will cause the contacts to not be closed with the force required to prevent excessive burning which eventually leads to carbon build-up on the contacts resulting in no power to the starter motor. |
| Shovie Member Since: 04 May 2021 Location: Wickwar area Posts: 14
You are correct James., I added the wire & it did not resolve the problem so I removed, stripped & cleaned the starter motor solenoid contacts that were badly pitted & its been no problem every since. |
The bypass wire cannot fix burnt contacts, it is purely preventative. |
| Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 355
Well it's just a little over 2 years later, I think I've covered about 25k kilometres in that time. Car is parked outside all year round, but I'm in Barcelona so we get rain but not much salt on the roads. I've just started having issues again. It started when my battery was dieing, since replacing the battery it was fine for a couple of weeks, but have had a few issues recently even with a good battery. I'm going to do the trigger mod I think, as I suspect that's going to be a long term fix. |
If the trigger feed isn't very strong, the contacts won't mate properly and there'll be considerably less current passed to the starter. Moreover, over time, the lack of a solid "thump" of the contacts together will mean the contacts burn out, lessening further the current available to the starter motor. This theory is supported by the fact that many people seem to experience the issues after or during them having a poorly battery, which of course, also lowers the available current to the starter and solenoid and is probably quickening the wear on the contacts. |
| All times are GMT |
