Home > Technical (L322) > 4.4 tdV8 Starter motor investigation.
Page 6 of 6 <123456
RovingCanary
I believe the theory is voltage drop reduces the force it activates with so doesn't make the contact convincingly. Presumably this in turn burns the contacts making the resistance even higher.
Could be wrong, but thought it was worth a try, and if it increases the time before I need to do the starter again then worthwhile leaving it on
Post #700946 27th Sep 2024 4:31pm
GraemeS
Australia
Low voltage and low current is due to inadequate gauge wiring and will cause the contacts to not be closed with the force required to prevent excessive burning which eventually leads to carbon build-up on the contacts resulting in no power to the starter motor.
Post #700966 27th Sep 2024 8:57pm
Shovie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Bournville
You are correct James., I added the wire & it did not resolve the problem so I removed, stripped & cleaned the starter motor solenoid contacts that were badly pitted & its been no problem every since.
Post #701175 30th Sep 2024 7:27pm
GraemeS
Australia
The bypass wire cannot fix burnt contacts, it is purely preventative.
Post #701182 30th Sep 2024 8:33pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
DeeJay wrote:
Can those that went ahead to file off / clean the solenoid copper contacts tell us if this is a lasting long term solution? If it needed to be done again, how long after?
Well it's just a little over 2 years later, I think I've covered about 25k kilometres in that time. Car is parked outside all year round, but I'm in Barcelona so we get rain but not much salt on the roads.
I've just started having issues again. It started when my battery was dieing, since replacing the battery it was fine for a couple of weeks, but have had a few issues recently even with a good battery.
I'm going to do the trigger mod I think, as I suspect that's going to be a long term fix.
Post #726835 25th Oct 2025 3:51pm
Siftah
James23 wrote:
I'm about to have to tackle this job myself as I had a click a few times in the last week.
The whole trigger wire mod doesn't make sense to me. The starter is obviously being told to 'go' hence the click, this to me says the trigger wire is fine?
If the trigger feed isn't very strong, the contacts won't mate properly and there'll be considerably less current passed to the starter.
Moreover, over time, the lack of a solid "thump" of the contacts together will mean the contacts burn out, lessening further the current available to the starter motor.
This theory is supported by the fact that many people seem to experience the issues after or during them having a poorly battery, which of course, also lowers the available current to the starter and solenoid and is probably quickening the wear on the contacts.
Post #726836 25th Oct 2025 3:57pm
Page 6 of 6 <123456
