![]() | Home > Maintenance & Mods (L322) > C1A09 Air Suspension Sensor fault |
| Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2298
So I have this fault and a google seems to suggest it’s a big issue on discos - there is a multi connector in the nsf arch and the wire to the sensor corrodes..
Anyone 😂 Current stable:
If I read the eas module it’s showing pressure on all corners all is above board but for some reason I can’t see reservoir pressure not sure if that’s the iid tool limitation or the fault Current stable:
Right - I have (I think) identified the problem - the reservoir pressure sensor that’s in the Wheel well was soaking wet inside the plug . Disconnecting it makes no difference to the fault codes so I have ordered a replacement over expensive sensor.
| Phoenix Member Since: 16 May 2022 Location: Gone Posts: 1631
Before you change the switch, check the harness connector for corrosion, you might need new pigtails for the connector housing. I'd also recommend finding out how and where from the water got in to prevent reoccurrence.
The connector that plugs into the sensor? That clean and I sprayed with contact cleaner and dried.
With the best will in the world, you can't check the condition of the connector electrical contacts without removing them from the housing, are the pins in the sensor corroded or discoloured at all? if so, then so will be the contacts in the connector housing - even if not, you should be checking them as a matter of course, if there is any corrosion at all, it will spread to the new sensor.
No corrosion on any of the pins and I soaked the whole plug in contact cleaner so hopefully that should do the job.
Contact cleaner isn't what you (probably) think it is - it removes grease and oils, that's it. It doesn't remove corrosion or check pin grip, or replace contact plating.
| davidrosenbloom Member Since: 02 May 2025 Location: USA Posts: 19
Gentlemen:
Can you read the reservoir pressure and does it look ok? Current stable:
Sure on the 09 but it goes to 220 psi and then its stable and then theres a bump lets say or an incline and all of a sudden the exhaust valve opens for a second and I see v using the GAP tool at the exhaust valve for a split second like its a mistake almost or an errant signal and that blows the or lets the reservoir down to 35 or 80 where it stays; compressor temp goes all the way up to 90 c but to be clear its not a compressor temp cut out.
| All times are GMT |
