Home > Technical (L322) > All four corners dropping
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
As it says, all four corners dropping overnight but not down to the bumpstops.
Disconnected the battery and no drop. So I think I don't have a leak.
Reading the manual, I think its dropping due to the wake up and relevelling procedure. Its making adjustments downwards as it cant get the car level.
I did notice that while doing a guided calibration a while ago that the movement of one of the rear corners was a bit jerky and I struggled to get it level using the GAP tool.
My conclusion is that I have a problem with the rear valve block.
I have ordered an O ring kit, will refurbish and see if this solves it
Am I on the right track? All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #726590 22nd Oct 2025 7:09am
JayGee
It 's more likley to be a faulty height sensor giving a false reading to the ECU which keeps dropping the car in an attempt to level it as you say. I think if you have disconnected the battery and it doesn't drop this indicates this even more. 2012 TDV8 Vogue (L322)
Post #726598 22nd Oct 2025 9:01am
Paddy X350
Thanks,
Is there a method or way I can identify a dodgy level sensor? All the best
Chris
Others;
2003 Jaguar Xjr
Post #726610 22nd Oct 2025 10:00am
JayGee
As you had a problematic calibration procedure with one of the rears this would be the best indication it's faulty. There are patern part sensors available but most people go for OE to ensure trouble free operation. 2012 TDV8 Vogue (L322)
Post #726611 22nd Oct 2025 10:10am
Paddy X350
I have recalibrated the suspension. It went OK this time and got all four corners pretty much spot on. Did this a few days ago and I haven't suffered any drop overnight since then. I have the valve block O ring kit on the way and will still rebuild the valve blocks when this arrives. All the best
Chris
Others;
2003 Jaguar Xjr
Post #726935 26th Oct 2025 8:18pm
