Home > Technical (L322) > L322 TDV8 3.6 L Coolant Pump bolts
thold691
Germany 2007 Range Rover Vogue TDV8 Java Black
Hello everyone,
I'm new to this forum and recently bought a 2007 RR Vogue L322 with the TDV8 3.6L engine as a project car, fully aware it has some issues. I found this forum while researching and have already gained valuable information, which I really appreciate.
I’m currently working on the cooling system, replacing the water pump, thermostat, and several hoses. I found the "Range-Rover-L322-Workshop-Manual-2007-2010.pdf" to be very helpful. However, I noticed a discrepancy in the torque values for the coolant pump bolts. The "General Specifications" section lists 10 NM or 7 lb-ft, but the installation instructions state 23 NM or 17 lb-ft. This has left me uncertain about which value is accurate.
Thanks for any input
Torsten
Post #726984 27th Oct 2025 2:30pm
