Home > General > Alarm Issue
pretlove
Big Cry nobody likes me Big Cry Big Cry Big Cry "RANGEISM WILL NOT BE TOLERATED"
Post #72974 19th Jul 2011 4:56pm
PJS
Ninja wrote:
Problem Solved Very Happy
Got a Friend to look at the bonnet switch and he cleaned it. This was on Saturday and it has not gone off since. Still cant work out why it went off at the same time each but hopefully all well now. Thanks for everyones help.
I hope your problem has been fully solved. If not, let us no and i'm sure we'll be able to help you Very Happy
Post #72984 19th Jul 2011 6:49pm
A1GSS
At the risk of incurring Scarey's wrath about searches again... ( Embarassed ) I'll post this in here as a vaguely related thread.
I've got an alarm problem. It goes off when I unlock the car. Seems unrelated to time / temp / whatever.... I'll take a look at the bonnet sensor tomorrow, but any ideas in the meantime welcome. Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #91749 12th Nov 2011 1:33am
strange one this graham, alarm going off when locking i can understand but when unlocking ?....
i would suggest someone has messed with the car whilst locked and for some reason the alarm only came on when you unlocked ,or the old bonnet switch playing up.
btw i dont wrath anyone graham.. Laughing ... - .- -.
Post #91765 12th Nov 2011 11:02am
............................Still cant work out why it went off at the same time each but hopefully all well now. Thanks for everyones help.
If the car is parked in the same spot every night the sun hits it around the same time every morning heating up the tinwork, so by 8:00-8:15 every morning there is enough heat on the bonnet to allow it to expand just enough to trip the switch....
Post #91766 12th Nov 2011 11:10am
A1GSS
Yes, but that's not my symptom at all. It goes off when you unlock it. Tried the other key, same behaviour.
Bonnet switch next. Graham
____
Post #91767 12th Nov 2011 11:20am
I doubt if your problem is a bonnet switch, but it can't do any harm to check.
My thought is water causing a short circuit somewhere in the alarm system
Post #91781 12th Nov 2011 12:29pm
A1GSS
Well, I can now report as follows...
Have disconnected the bonnet switch. Somewhat surprisingly, problem appears to have gone, spent about an hour of open/shut action, probably done it 20 times or so.
So, although probably too early to be sure, this looks like a new symptom of the same problem.
Next q is how do I get the bonnet switch out? Graham
____
Post #91794 12th Nov 2011 3:08pm
supershuttle
I didn't replace mine, just hit it with plenty of switch cleaner and so WD40, been fine ever since ..........................................
What's that noise Rolling with laughter Geoff
Post #91809 12th Nov 2011 5:48pm
A1GSS
Laughing Very good. I might try that. Or just leave it disconnected for a week first. Graham
____
Post #91813 12th Nov 2011 6:27pm
supershuttle
I just remembered the other thing I did was to stick a little rubber pad on the bonnet where the switch touches to push it a bit further home Smile Geoff
Post #91825 12th Nov 2011 8:14pm
A1GSS
Cool, thanks. I can test the switch easily enough too. Seems very flimsily mounted, just clips in. Graham
____
Post #91829 12th Nov 2011 8:40pm
A1GSS
48 hours later, still working fine with the bonnet switch disconnected... Thumbs Up Graham
____
Post #91953 13th Nov 2011 3:56pm
A1GSS
One week on, my alarm problem has definitely gone. No issues. Yay Thumbs Up
Have removed the switch (a BMW part... Shocked ) and it's sticky. See what a bit of WD40 might do, have also PM'ed Dan for a price for new one. Graham
____
Post #93317 19th Nov 2011 5:39pm
