![]() | Home > General > Alarm Issue |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
At the risk of incurring Scarey's wrath about searches again... ( |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
strange one this graham, alarm going off when locking i can understand but when unlocking ?....
If the car is parked in the same spot every night the sun hits it around the same time every morning heating up the tinwork, so by 8:00-8:15 every morning there is enough heat on the bonnet to allow it to expand just enough to trip the switch.... |
Yes, but that's not my symptom at all. It goes off when you unlock it. Tried the other key, same behaviour.
I doubt if your problem is a bonnet switch, but it can't do any harm to check.
Well, I can now report as follows...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3945 ![]() ![]() ![]() |
I didn't replace mine, just hit it with plenty of switch cleaner and so WD40, been fine ever since ..........................................
I just remembered the other thing I did was to stick a little rubber pad on the bonnet where the switch touches to push it a bit further home |
Cool, thanks. I can test the switch easily enough too. Seems very flimsily mounted, just clips in. Graham
48 hours later, still working fine with the bonnet switch disconnected... |
One week on, my alarm problem has definitely gone. No issues. Yay |
