![]() | Home > Technical (L322) > Lots Of Black Smoke! |
| trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 141
I would still check the turbo - same happened to mine didnt seem to lose that much power but about 30mph plus and I got that smoke - turbo knackered - Landy have a bit of a shortage on them too. Not cheap. Mine was over 2 grand inc fitting |
| PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506
Check the turbo, it might just be that. But its usually a pricey job |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Someone else mentioned this the other day and they were told to change the breather on the rocker cover. There on ebay for about £20 so might be worth a try before you go spending £1k on turbo etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94
Thanks for the replies folks!
saying that about the rocker cover there is a bit of oil across the engine cover and just below the fuel filter, I checked that the oil filter was tight as that's where it looks like it coming from and it's ok so could be that |
Im not 100% ofay with the TD6 but this is the thread from the other day : http://www.fullfatrr.com/forum/topic6722.html
Thanks alot rob |
| Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 746
Isn't black smoke a sign of over fuelling, and blue/grey smoke would be a sign of burning oil ? |
| herman maire Member Since: 28 Nov 2010 Location: up north Posts: 51
Hello,
it has done 74k, change the small rocker filter on the range and still blowing black smoke, does it take a good few miles to clear all the crap out? |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Sorry, just tickled me a bit. |
On a petrol yes. On a diesel blue smoke can also be unburnt fuel as well as burning oil.. |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Might also be worth checking to see if an intercooler hose has collapsed. |
| letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854
clean your egr valve out. 2004 black Vogue TD6 |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Could be a split turbo hose?
| All times are GMT |
