Home > Technical (L322) > Lots Of Black Smoke!
Wiggins
2011 Range Rover Autobiography 4.4 V8 Santorini Black
big problem folks, I have a TD6 and when around 2000-2500rpm and at 30mph there's tons of black smoke coming out the exhausts and when on full acceleration it seems as if there is air blowing out the front blowers but no air con on, initial thought was the turbo was gone but it doesn't seem to be loosing that much power and been told it could be a burst pipe somewhere from the intercooler to the turbo, any one have any other ideas?
Cheers
Post #73071 20th Jul 2011 8:28am
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
I would still check the turbo - same happened to mine didnt seem to lose that much power but about 30mph plus and I got that smoke - turbo knackered - Landy have a bit of a shortage on them too. Not cheap. Mine was over 2 grand inc fitting Big Cry
Although did get 1K of that back through the warranty Id taken out. Cool 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #73073 20th Jul 2011 8:44am
PJS
Re: Lots Of Black Smoke!
Cheers
Check the turbo, it might just be that. But its usually a pricey job Surprised
Post #73074 20th Jul 2011 8:49am
Someone else mentioned this the other day and they were told to change the breather on the rocker cover. There on ebay for about £20 so might be worth a try before you go spending £1k on turbo etc. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #73078 20th Jul 2011 9:13am
Wiggins
Thanks for the replies folks!
saying that about the rocker cover there is a bit of oil across the engine cover and just below the fuel filter, I checked that the oil filter was tight as that's where it looks like it coming from and it's ok so could be that
Post #73079 20th Jul 2011 9:31am
Im not 100% ofay with the TD6 but this is the thread from the other day : http://www.fullfatrr.com/forum/topic6722.html
It mentions a rocker breather and seems quite common on the BMW forums and smoky TD6's [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #73083 20th Jul 2011 10:17am
Wiggins
Thanks alot rob Very Happy will change that and let you know how I get on
Post #73086 20th Jul 2011 10:47am
Johnte
Isn't black smoke a sign of over fuelling, and blue/grey smoke would be a sign of burning oil ?
Post #73096 20th Jul 2011 12:33pm
herman maire
Canada
Hello,
How many miles on the truck? I would be shocked if you had a low miles truck and the turbo was faulty. 2003 RR 4.4 only 40k miles (current)
2004 RR 4.4 ( just sold)
2000 RR 4.6 (sold)
1959 series 2 109
1956 series 1 1956
Post #73100 20th Jul 2011 1:40pm
Wiggins
it has done 74k, change the small rocker filter on the range and still blowing black smoke, does it take a good few miles to clear all the crap out?
Post #73125 20th Jul 2011 4:39pm
mzplcg
Rob2529 wrote:
Im not 100% ofay
Rolling with laughter Rolling with laughter Would that be Au Fait ?? Bow down Bow down
Sorry, just tickled me a bit. Embarassed
Post #73129 20th Jul 2011 5:16pm
mzplcg
On a petrol yes. On a diesel blue smoke can also be unburnt fuel as well as burning oil..
Post #73131 20th Jul 2011 5:18pm
Might also be worth checking to see if an intercooler hose has collapsed.
Post #73133 20th Jul 2011 5:22pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
clean your egr valve out. 2004 black Vogue TD6
Post #73134 20th Jul 2011 5:26pm
simon1233
Could be a split turbo hose?
I had the same symptoms as you described on my mercedes e270 CDI estate, £25's worth of hose later and it was sorted Thumbs Up
Even made the same noise as you describe, like the front vents are blowing full on, but without actually being on
Post #73145 20th Jul 2011 7:28pm
