Home > In Car Electronics (L322) > TV in motion
Page 1 of 4 1234>
rwilson
United Kingdom 2009 Range Rover Vogue TDV8 Zermatt Silver
TV in motion
I have being trying to fit a plug and play TV in motion to my 2009 Vogue. After leaving the ignition off for about 10 mins I fitted it. I then turned on the TV which worked, but message came up with suspension fault on the dash. The TV does not work in drive as it now should (sound only, as the manufacturer intended). When I removed the unit the fault message disappears and everything returns to normal
Any thoughts?
Regards Richard
Post #73842 26th Jul 2011 7:01pm
Re: TV in motion
Any thoughts?
Regards Richard
Almost certainly the TV im motion module is causing havoc with the cars electronics. I had a similar problem with my BMW which when I put it in, the dash boards lit up like a Christmas tree, Turned out I had been supplied with the wrong module.
I would suggest you contact the supplier to double check what they've supplied.
Are there any swicthes on the module at all? Got - 2017 SDV8 Autobiography in Loire Blue
Post #73843 26th Jul 2011 7:15pm
rwilson
yes 3 DIP switches all in the up position as instructed. To be fair supplier has offered a refund but thought I would ask here first before sending it back.
Richard
Post #73845 26th Jul 2011 7:25pm
have you tried all the different combinations of the switches?
Are there any markings on the box that say what car and model it's for? Got - 2017 SDV8 Autobiography in Loire Blue
Post #73847 26th Jul 2011 7:43pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Hi Richard, can you post a link where you bought the TV in motion box from? The 753 hack is getting a bit tedious now.
Gone - Range Rover Supercharged 2006
Post #73853 26th Jul 2011 7:57pm
rwilson
Says it was for Disco 3, Sport and Vogue. I asked to make sure that Vogue meant 2009 not older style 2005 type. I haven't tried changing the switches as the guy said that they should be all up.
Was an ebay purchase.
Post #73858 26th Jul 2011 8:24pm
Vogue
Justin, what is the 753 Hack? I know about the 1791 but have never heard of the 753??
Post #73870 26th Jul 2011 9:59pm
JustinP
It enables TV on the move Thumbs Up
http://www.fullfatrr.com/forum/topic2243.html
Post #73871 26th Jul 2011 10:03pm
Vogue
ah Thumbs Up thanks muchly
Post #73874 26th Jul 2011 10:16pm
stu
this is a question for those of you who have had a look at the back of the head unit. does the touch screen (MOST) headunit have a 17 pin connector or a quadlock?
would appeciate any help. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74225 30th Jul 2011 8:07am
heres a pic of the back of the screen joe..
Post #74235 30th Jul 2011 10:05am
stu
thanks for the pic.. Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74267 30th Jul 2011 1:57pm
stu
couls someone with a (MOST) touch screen systen, please let me know how to remove the head unit to connect my new VIM unit?? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74549 2nd Aug 2011 8:37pm
stu
just a quick bump for my last post.
could anyone who has fitted a VIM to there FF give me a few pointers, or is it straight forward??
the instructions i got with it are for a 2007 onwards, where you drop the glove box and everything is there. i believe in the 2006MY you have to remove the dash top panel? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #75029 6th Aug 2011 2:48pm
SteveMFr
Site Sponsor
For the pre-interior-facelift models, go to youtube and search powerfulUK's vids for the video on installing the aftermarket nav. It shows exactly how to get to the head unit.
I've never taken a new-dash model apart yet...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #75075 6th Aug 2011 9:52pm
Page 1 of 4 1234>
