![]() | Home > Technical (L322) > Rear number plate lights L322 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
first thought would be the fuse, second would be to take the tailgate inner panel of and have a look at the wiring..panel is very easy to get off. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Doesn't your display a light error when you startup and get out? I know when my i put LED's in mine the bonging was constant untill i put the ones with resistors in. That might indicate something more than a duff bulb. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 ![]() ![]() |
Hi Scarey thx for the reply
And no there are no bulb warnings showing This is confusing me also |
by coincidence i've had my reverse bulbs out this week and they are definitely 12 volt 6 watt jobbys..cant understand why you're only 6 volts there.. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
If you only have a maximum of 6v you have a bad connection somewhere.
I been looking at it for a couple of hrs today and I'm still none the wiser
Does anyone know if there is a fuse for the number plate lights because I can't see anything relevant in the manual ?
Have you looked at the sticker on the back of the fuse box? Im sure it has more fuse locations than in the manual. I will look at mine tomorrw and see. Currently in work with the wife's car. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thx Rob I have looked but maybe I just can't see it
dont think it is a fuse ..if it was then you wouldn't get any voltage coming through..as a temporary fix you could very easily run a feed from the side lights to the number plates lights.. |
Thx Scarey I think your right I have just asked LR no fuse so now I need to recheck wires and earths oh joy lol |
Right pretty sure I know the problem after a lot of investigating
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Jon ![]() ![]() ![]() ![]() Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone. SWMBO: 2022 RRS D300 Autobiography, Firenze Red. Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD |
