Home > Technical (L322) > Rear number plate lights L322
JonP
2003 Range Rover Vogue 4.4 V8 Epsom Green
Hi guys I had her serviced today and the garage mentioned that neither of my rear number plate lights are working, they tried changing the bulbs but still no joy
Any body else had this problem and if so what was it
Many thanks in advance
Regards
Jon
Post #74207 29th Jul 2011 10:19pm
first thought would be the fuse, second would be to take the tailgate inner panel of and have a look at the wiring..panel is very easy to get off.
Post #74241 30th Jul 2011 10:23am
Doesn't your display a light error when you startup and get out? I know when my i put LED's in mine the bonging was constant untill i put the ones with resistors in. That might indicate something more than a duff bulb. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #74243 30th Jul 2011 10:48am
JonP
Hi Scarey thx for the reply
I have taken rear trim off and wiring looks to be ok I cannot seem to find a fuse which covers the number plate lights
The wiring looks to also be feeding the upper tailgate latch which is working ok
I put a multi meter across the bulb holder and a get around 6v which I think is possibly to low this is the holder on nearside of boot on the offside there is no voltage
Post #74248 30th Jul 2011 11:19am
JonP
And no there are no bulb warnings showing This is confusing me also
Post #74249 30th Jul 2011 11:20am
by coincidence i've had my reverse bulbs out this week and they are definitely 12 volt 6 watt jobbys..cant understand why you're only 6 volts there..
Post #74254 30th Jul 2011 11:59am
If you only have a maximum of 6v you have a bad connection somewhere.
Have you had a close look at the bulb holders, corrosion of the contacts?
Might be worth using a bit of fine emery on the contact surfaces.
If you do clean them and they work remove the bulbs and smear the contact surfaces with Vaseline before you put them back in permanently.
Post #74256 30th Jul 2011 12:07pm
JonP
I been looking at it for a couple of hrs today and I'm still none the wiser
Contacts look ok nice and clean still only getting 6v out of nearside light socket with the bulb out But nothing when I put the bulb back in and nothing at all from offside lamp holder upper tailgate switch works fine
Sad
Post #74283 30th Jul 2011 6:27pm
JonP
Does anyone know if there is a fuse for the number plate lights because I can't see anything relevant in the manual ?
It's know one of these little problems that's bugging me lol
Post #74333 31st Jul 2011 2:41pm
Have you looked at the sticker on the back of the fuse box? Im sure it has more fuse locations than in the manual. I will look at mine tomorrw and see. Currently in work with the wife's car. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #74358 31st Jul 2011 9:06pm
JonP
Thx Rob I have looked but maybe I just can't see it
I have also checked the net but no luck over on the bimmer forum they talk about corroded lamp fittings but I can see no evidence of this on mine I have also pulled back the rubber boot at the top of the tailgate and had a look at the wires but cannot see any that are damaged
So any fresh input would be welcomed
Many thanks
Jon
Post #74361 31st Jul 2011 9:24pm
dont think it is a fuse ..if it was then you wouldn't get any voltage coming through..as a temporary fix you could very easily run a feed from the side lights to the number plates lights..
Post #74372 1st Aug 2011 7:47am
JonP
Thx Scarey I think your right I have just asked LR no fuse so now I need to recheck wires and earths oh joy lol
Post #74376 1st Aug 2011 8:47am
JonP
Right pretty sure I know the problem after a lot of investigating
It looks like the light control module has suffered some water damage and has blown a chip Censored
This might explain why no fault was registered on the check panel
Looks like I need a new one or working second hand one oh well something else to fix Big Cry
Post #74445 1st Aug 2011 8:38pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Jon Shocked you keep breaking it Big Cry LCM is in the drivers footwell and I have never found water in there or any other part of the interior Confused Both bulbs were working as I checked everything electrical regularly, glad to hear headrest was an easy fix Thumbs Up
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #74456 1st Aug 2011 10:16pm
