![]() | Home > Technical (L322) > Testbook |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i've always had this feature so cant help re the activation bit....but if you had it before you went into the dealer then it sounds that when they activated and ticked the box for those things ,they forgot to tick this feature as well.. |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
that's what i thought, but they said they put both their testbook units on the car and couldn't get it to activate again.
lets hope they sort it out...let us know the outcome stu.. |
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1112 ![]() ![]() |
It does seem that the steelers are totaly cluless over most of this. All any of thees things need is the correct algorythm. The problem is that the muppet in the workshop has no concept of what is going on and even less idea how to sort it.
just to carry on my tales of woe.. |
just an update really. FF booked into stealers next week for them to hopefully sort it all out at their expense may i add!!
The PDC ECU's die at the drop of a hat. Maybe find one with working front and rear sensors and swap the ecu's over. You need to rule out the ECU before worrying about the sensors/wiring.
no the A/C isn't on all the time, i will try using it a bit more.
stu, not guaranteed to work but, a battery disconnection for a few hours sometimes reboots the ecus and clears any problems, but dont forget to re-set the the steering parameters by turning the steering wheel full lock left then right when the battery is re-connected.... |
The PDC ECU lives in the boot, behind the right panel. You need a copy of the workshop manual, check the WiKi out.
thanks for help and info guys, i will try things out as soon as i can.... |
well back to stealers for third time this morning... |
