Home > Technical (L322) > Testbook
stu
Testbook
Had FF in stealers earlier in the week to get a couple of bits and pieces activated.
when i got home had my window open so as usual went to lock car and put window up with remote. door locked, but no window movement!!
had it back in yesterday for them to sort this out. after 1.5 hrs and a lot of huffing and puffing, they think it requires a software upgrade to sort this out.
they sent a message with all the details to L/R and said they should receive a file back with the relevant cure.
has anyone ever had an issue like this before?
i would have thought that if it's in the user handbook as an option to be activated by the dealer it should really work without any extra upgrades!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74233 30th Jul 2011 9:24am
i've always had this feature so cant help re the activation bit....but if you had it before you went into the dealer then it sounds that when they activated and ticked the box for those things ,they forgot to tick this feature as well..
Post #74237 30th Jul 2011 10:11am
stu
that's what i thought, but they said they put both their testbook units on the car and couldn't get it to activate again.
chief sparky said they have had a few issues of late with things like this and L/R just send a file via email which they upload to testbook and download to my car and hey presto all should be well again.
not my money they are spending so it just needs fixing now so it all works as before them touching it. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74269 30th Jul 2011 2:02pm
lets hope they sort it out...let us know the outcome stu.. Thumbs Up
Post #74275 30th Jul 2011 2:38pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
It does seem that the steelers are totaly cluless over most of this. All any of thees things need is the correct algorythm. The problem is that the muppet in the workshop has no concept of what is going on and even less idea how to sort it.
I blame the manufacturers for failing to train the staff but at the same time guarding the acces codes.
All of them are just a tick in a box and a reset to factory for when it goes pear shaped. letters not necessarily in the right order
Post #74293 30th Jul 2011 8:16pm
stu
just to carry on my tales of woe.. Sad
my front park sensors have stopped working now too, they were ok on friday before it went into the garage.
is it possible that they have screwed these up as well?
the rears work perfectly, the light above the button doesn't flash and the sensors don't click, they are totally dead.
just getting a bit fed up now. car was perfect before i took it in to stealers, now getting electric gremlins.. Mad Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #74336 31st Jul 2011 4:34pm
stu
just an update really. FF booked into stealers next week for them to hopefully sort it all out at their expense may i add!!
took it to the independant garage that i bought it from yesterday for him to put it on his autologic.
the funniest thing happened... it didn't read any faults, even though the front sensors don't work. it reads all four front and rear sensors, we turned the switch on on the dash with autologic, activated the light and made the rears beep, but absolutley nothing from the fronts. they all have the same reading front and rear except when you walk behind the rears the reading drops like it should.
the guy in the garage was stumped!! he thinks that L/R have removed a file or something silly and not known they have done it. well next week is D-Day for them to put right everything that is not working properly since they laid their hands on it.
does anyone have any ideas about the front sensors? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #76221 14th Aug 2011 7:18pm
dan_uk_1984
The PDC ECU's die at the drop of a hat. Maybe find one with working front and rear sensors and swap the ecu's over. You need to rule out the ECU before worrying about the sensors/wiring.
Don't worry about your ABS ECU - sounds like they are just trying to screw you for some extra cash next time you come in!
Do you leave your A/C on all the time? It removes the moisture from the air, turning it off can lead to various electrical gremlins... Including failing ECU's.
Post #76230 14th Aug 2011 8:38pm
stu
no the A/C isn't on all the time, i will try using it a bit more.
just seems funny to me that the rear works but the front doesn't. surely yet again the autologic would pick up a fault??
where is the PDC ECU located? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #76237 14th Aug 2011 9:32pm
stu, not guaranteed to work but, a battery disconnection for a few hours sometimes reboots the ecus and clears any problems, but dont forget to re-set the the steering parameters by turning the steering wheel full lock left then right when the battery is re-connected....
Post #76238 14th Aug 2011 9:37pm
dan_uk_1984
The PDC ECU lives in the boot, behind the right panel. You need a copy of the workshop manual, check the WiKi out.
I've gone through 3 PDC modules - the rear doesnt work in my new one either now Evil or Very Mad If thr ECU doesnt realise it is faulty then it wont store a fault code for you.
Post #76239 14th Aug 2011 9:43pm
stu
thanks for help and info guys, i will try things out as soon as i can.... Thumbs Up Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #76252 15th Aug 2011 5:32am
stu
well back to stealers for third time this morning... Crying or Very sad
collected it this afternoon and was told that it had had a software upgrade. my windows and roof open and close again from the remote and my front park sensors work too, seems like all systems are go again... Very Happy
being the compulsive fiddler that i am i was experimenting with the voice control again on the drive home and i managed to turn the display on and off via voice commands, can't remember being able to do this before, must be part of the software upgrade.
anyway third time lucky!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #77268 23rd Aug 2011 6:12pm
