![]() | Home > Technical (L322) > No air from central row of dash vents - why? |
Best to leave it on Auto I find. It often takes a few minutes to sort itself out, especially if there is a sudden temperature change.
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Cheers Dan, I don't think mines sorts itself out after a minute, I drove home from work today for over 30 minutes and the air still wasn't coming out of the face vents, its like its confused where the air is needed. Even if I press the manual override button the air still comes out of the front screen and footwell vents
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
theres a motor behind the dash that operates flaps [blend motor?]..sometimes the flaps get stuck or the motor fails.. |
I would guess it's the blend motor then. Really you need to get it plugged in and checked out.
signature needs changing dan.. |
Not just yet... Don't want to jinx it! ![]() |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Just found this thread when looking for a fix for a new problem - i noticed today that I had no air coming from the centre vents, even when taking the controls off full automatic and selecting the centre vents - the same applied to the footwells even although the fan is working - air just seemed to be coming from the screen vents.
Either the engine temperature is not coming right up to the specified temp or the FSR is knackered |
Engine temp is fine and the FSR must be OK as the fan is running OK and can be controlled by the fan speed controller OK...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Had the same problem last week, no air from the face vents, everything else ok.
