Home > Technical (L322) > No air from central row of dash vents - why?
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
On occasion no air is being blown out of the central row of the dash vents, it blows onto the front screen and down to my feet but nothing from the vents that face into the car.
The air con is cold and the climate sensor works, adjusting the fan speed when I increase / decrease the cabin temperature but on occasion no air is coming from the centre vent, the top of dash vent and the 2 outer dash vents.
This happens even if I turn the system to manual, still no air.
I've noticed though that I have exited the car for a short time then on my return the system is perfect, lots of air from all vents.
Anyone know what's happening?
When I have it in auto mode, both lights in the auto button are lit, is that the best way?
Carl
Post #74919 5th Aug 2011 3:20pm
dan_uk_1984
Best to leave it on Auto I find. It often takes a few minutes to sort itself out, especially if there is a sudden temperature change.
I find if I manually select face vents it can take a minute to select it (whilst it purges the air apparently) and then the air comes out fine. Then if left on Auto it changes it to where its needed, according to its "map"
Dan
Post #74921 5th Aug 2011 3:48pm
carlos50
Cheers Dan, I don't think mines sorts itself out after a minute, I drove home from work today for over 30 minutes and the air still wasn't coming out of the face vents, its like its confused where the air is needed. Even if I press the manual override button the air still comes out of the front screen and footwell vents
Carl
Post #74928 5th Aug 2011 4:30pm
theres a motor behind the dash that operates flaps [blend motor?]..sometimes the flaps get stuck or the motor fails..
Post #74938 5th Aug 2011 5:43pm
dan_uk_1984
I would guess it's the blend motor then. Really you need to get it plugged in and checked out.
D
Post #74957 5th Aug 2011 8:59pm
signature needs changing dan.. Wink
Post #74962 5th Aug 2011 9:27pm
dan_uk_1984
Not just yet... Don't want to jinx it!
Post #74972 5th Aug 2011 9:59pm
Laughing
Post #74973 5th Aug 2011 10:04pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Just found this thread when looking for a fix for a new problem - i noticed today that I had no air coming from the centre vents, even when taking the controls off full automatic and selecting the centre vents - the same applied to the footwells even although the fan is working - air just seemed to be coming from the screen vents.
I switched the car off and then restarted it and all OK
This has happened several times now so I'm unsure what the issue is - anyone any ideas ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #161074 1st Jan 2013 10:22pm
Either the engine temperature is not coming right up to the specified temp or the FSR is knackered
Post #161079 1st Jan 2013 10:35pm
CG-SC
Engine temp is fine and the FSR must be OK as the fan is running OK and can be controlled by the fan speed controller OK...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #161083 1st Jan 2013 10:38pm
Had the same problem last week, no air from the face vents, everything else ok.
Connected the RSW All Comms unit, cleared any faults and the face vents are now fully working.
Tends to suggest a fault was logged and stopped the vent function operating.
Post #170584 6th Feb 2013 10:10pm
