Home > Maintenance & Mods (L322) > egr blanking kit for td6
Page 4 of 15 <123 45 ... 131415>
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
I had the EGR blanked AND the Lamba probe + electronics removed from my cat equipped Defender TDi300 - the improvements in performance and reduced fuel consumption were appreciated but also the engine ran more smoothly.
Lots of Disco3's and RRS's are now running with blanked off EGR's - take a look on their forums. Also Pete Bell of Bell Auto Services sells EGR blanking kits for all the modern Land Rover engines. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #75021 6th Aug 2011 12:21pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Ive ordered one, once fitted, i will post an update.
Post #75024 6th Aug 2011 1:12pm
maybe a 'how to' as well paul.. Thumbs Up
Post #75035 6th Aug 2011 3:45pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Joe90 wrote:
Do I need to block off the pipe on the EGR?
Will now do some testing to see if mpg/performance improves....of course I don't know if my EGR is gunged up/working ;)
No, there's no need to block the pipe on the EGR...
Post #75223 8th Aug 2011 10:57am
adara wrote:
Will now do some testing to see if mpg/performance improves....of course I don't know if my EGR is gunged up/working Wink
Thanks .
Post #75228 8th Aug 2011 12:06pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
nicedayforit wrote:
The other way to avoid buying a kit is to simply undo the two bolts that hold the byepass hose connection to the exhaust manifold and slide a piece of thin sheet metal between the manifold face and the hose connection face and tighten the bolts back down. The only complication is will the two bolts slaken without problems, sometimes they can be "awkward"
Doing it this way blocks the exhaust gases for good without worrying about the egr.
Buying a kit does have the advantage that that it could be just a 10min job without any likely complications.
So before we trundle off to France with some long motorway runs, I'm interested in any mpg improvements (and no, I don't want to buy a blue motion car Laughing ) - to be very specific however, using the diagram on page 30-1-10 here http://www.landroverweb.com/Pdf-files/Manu...0Rover.pdf is this the green pipe just above where the "number 8" line points to ?
I was pondering whether a section from a drinks can might be thin enough to shape easily ...
Post #75631 11th Aug 2011 10:01am
Yes thats the pipe connection you need to blank.
Drinks can metal would be too thin in my opinion, it would probably burn with the exhaust manifold heat. You would be better with a piece of sheet steel from the side of a tin can, something like dog food etc.
If you can't manage to blank of the pipe before your hols you could do as adara has suggested and remove the vacuum pipe from the egr valve and seal the pipe with a nail, ball bearing etc, it must be sealed tight . You don't need to seal off the metal pipe on the egr valve that you removed the vacuum pipe from but a bit of plastic tape over the end would keep dirt out for possible future use. 5min job.
It's pipe 2 as below.
If you go the vacuum pipe removal route you just have to hope the egr valve is closed to the exhaust gases to get the benefit.
The other option is to disconnect the exhaust hose from the egr at 1 above, seal it and then refit it but I haven't quite figured a simple way to do that yet.
Post #75637 11th Aug 2011 10:28am
VaguelyVogue
Many thanks - the photograph really helps to show which pipe is which !
I'm now tempted to remove the whole EGR valve, clean it out and check that it is fully closed before I plug the vacuum pipe (something like a 1" slug of silicone sealant would seal the pipe and allow reattachment to the valve).
Regarding sealing pipe 1, I'll have a look tonight but it may be possible to fit a metal bottle top over the valve body before reattaching the stainless pipe and clamp. I'm guessing that without a flow of exhaust gas, it will be much cooler, so the type of metal will be less important.
Post #75655 11th Aug 2011 11:43am
The silicone is a good idea, never thought of that.
Bottle top or something like a copper pipe end cap, or possibly a lump of metal in the egr inlet pipe from the exhaust manifold.
Be interested to know how you get on.
Post #75659 11th Aug 2011 11:55am
VaguelyVogue
Ok - blocking the vacuum pipe was easy and quick (slug of silicon).
The stainless steel exhaust gas pipe (number 1 in the photo) appears to be crimped onto the EGR - so not easy or quick to remove (I didn't).
The EGR was full of sooty cr*p (as predicted) but the lower Allen bolts were a pain to reach - so I'll try to get to them at the weekend.
Post #75833 11th Aug 2011 10:50pm
VaguelyVogue
The mpg was showing 31 (at 55mph) - that's 24.5mph normally Thumbs Up
Post #75940 12th Aug 2011 7:23pm
remember it takes a while to give an accurate figure...
Post #75943 12th Aug 2011 7:43pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
looks promising. Mine will be done mid september when the car is in for its MOT. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #75951 12th Aug 2011 8:05pm
i disconnected and blocked off my vacuum pipe yesterday but not had a try to see what effect doing this has yet...i dont know whether the egr valve is in the open or closed position so possibly i wont get any mpg or performance increase..i might have to buy a blanking kit to get the full benefit..
Post #76431 16th Aug 2011 10:29am
to quote a lyric from a queen record ''its strange but its true'' but since my vacuum pipe disconnection, my town driving mpg has risen from 19 to 21/22mpg and, this is the strange bit , the dash mpg readout is updating every 15 seconds or so whereas before it was once every 10'ish minutes..
Post #76562 17th Aug 2011 12:13pm
