Home > Technical (L322) > Vibration at around 40mph.......Diff problem? |
If you knock it down to 3rd or up to 5th does the problem go away?
7th Aug 2011 6:52pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
whats the mileage V8 facelift Range Rover Autobiography 22" wheels.
7th Aug 2011 10:04pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Dan...... not sure regarding the gear change, will check tomorrow. Ruled out any problems with the wheels by changing from 19's to 2010 20's, same issue still there.
7th Aug 2011 10:17pm |
my money is on your torque converter this gives you a shudder like going over a cattle grid but not as bad, do you find it if you give the car more throttle from a stand still and keep it in the higher revs it does not do it or is lighter vibration, V8 facelift Range Rover Autobiography 22" wheels.
7th Aug 2011 10:41pm |
Bang on Dave
7th Aug 2011 10:53pm |
i dont think so as its not electrical, its the clutchs trying to lock..the main thing if it is you dont want it to start breaking up as it will kill you box as well, did you say you ave only had it 3 weeks, was it privet or trade V8 facelift Range Rover Autobiography 22" wheels.
7th Aug 2011 11:25pm |
Trade
8th Aug 2011 12:13am |
no, as the torque starts to break up all bits of it start to pump round your box,this is what does the damage, if you catch it early enough you can save the box as the filter does its job, it will need flushing through and the oil cooler in most cases get changed. its not a cheap repair but if it is indeed the converter get it back to your trader.. V8 facelift Range Rover Autobiography 22" wheels.
8th Aug 2011 12:31am |
oh, does it change up and down more then you would think.. V8 facelift Range Rover Autobiography 22" wheels.
8th Aug 2011 12:32am |
No, gear change seems fine.
8th Aug 2011 12:48am |
Well the dealer was very understanding!!
8th Aug 2011 7:12pm |
hi, is the dealer who you bought it from.. V8 facelift Range Rover Autobiography 22" wheels.
8th Aug 2011 7:41pm |
I bought it from a car dealer, who doesn't have his own workshop.
8th Aug 2011 11:14pm |
JonP Member Since: 11 Jul 2011 Location: Surrey Posts: 51 |
Any update on this how did you get on at the dealer |
11th Aug 2011 11:12pm |
