![]() | Home > Maintenance & Mods (L322) > Dash lights very dim and LED lights dim in roof |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Hello all,
welcome simes..
How bizarre. The lights in the binnacle are LED's and are not "user replaceable" however some have upgraded them to white LED's so it must be possible...
I've had a look at them and they look original - and the book mentions that they are supposed to be there! Might be worth taking them out I suppose to see what happens... |
There are LED's in the roof (front & rear) - this gives the "waterfall lighting" Next time its dark, put your hand up there and you will see the light. They are very directional so they don't distract the driver... One wouldnt usually even notice them. They are linked with the LED's in the door handles and the door pockets I believe. ![]() |
Thanks for this Dan. The pixels are all good - that lights up and works perfectly! It's just the lighting - also none of the switches in the centre console light up - I guess they are supposed to, or are they lit by the light from the LEDs in the roof light - when they work too... I was thinking LCM - I guess they are expensive? |
![]() They don't work either... No light in the pockets or door handles. |
i stand corrected re the leds , looked like normal baynet type bulbs to me..... |
Apart from my normal pessimism regarding Land Rover faults, this is why I suspec the LCM - I reckon it's bulbs in the steering wheel - that are working perfectly - and everything else that is LED is not... |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
What and where are these "water fall" lights? I have the big light in the middle and 2 map lights? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Have you ever picked up a brochure for the car?
Actually I haven't only the new My2011 which i no use to me. |
i assumed OP was on about the light below red circles in dans pic.... |
I have LEDs in my main bulbs through out the car and have no problems. I do however have a blown bulb/LED in the dash binnacle. where the milage is doesn't illuminate. Will try and get a pic later to see if its any help to Simms. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
