![]() | Home > Maintenance & Mods (L322) > Sankey Trailer & Nato Hitch on a FFRR |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi All,
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Incase you haven't seen wiggs's trailer.
Yep, I've looked at all the photos in Adrians thread |
The problem with the Nato hitch is that it will allow the trailer to rattle about on the hitch. Best convert to a standard hitch if possible for a more comfortable drive. |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
Mine dosent rattle about |
Just use plenty of grease but they rattle about as they are designed to be really used under the most extreme conditions we have around the globe |
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
If you buy the type shown in your first photo you can turn the tow coupling tube upside down and bolt it underneath the trailer A frame instead of on top. It will then ride level with your standard height tow bar.Theres a bit of work modifying the brake linkage but ive seen it done before. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
isnt this trailer going to slow you down a bit justin....
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
60mph. |
is it also only the first two lanes on the motorway.. |
Towing regs should be waived for FFRR's. Towing a small 6x4 trailer at 60mph - WTF is that about. |
That is the speed limit on the kings highway, off piste its what ever you want |
tbh when you see these trailers being pulled at 70/75 mph and they start bouncing side to side ,then that's probably why there's a speed limit for them... |
On the drive to the south if France, we saw many trailers being towed at 80mpg, and they all looked stable.
