Home > General > three beeps
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
three beeps
when i turn the ignition on i hear three beeps but no message on the dash, i have a54 plate TD6 vogue. any of you guys know what this means? Confused
Post #78860 2nd Sep 2011 2:40pm
Sounds like you have a tracker fitted, search the forum, lots on this. .
Post #78861 2nd Sep 2011 2:43pm
from memory i think its a tracker device bleeping, might be wrong though...
edit ..its a tracker. Thumbs Up
http://www.fullfatrr.com/forum/topic4213.html?highlight=3+beeps
Post #78862 2nd Sep 2011 2:43pm
andyboy
had the car nearly 2 years can't remember doing it before,and i know its not the clock as it didn't happen on the hour.
Post #78884 2nd Sep 2011 3:56pm
daveo
have you come across a small credit card size fob...while cleaning the car.. V8 facelift Range Rover Autobiography 22" wheels.
Post #78896 2nd Sep 2011 5:30pm
andyboy
unfortunately no
Post #78900 2nd Sep 2011 6:02pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Have a look in the boot and get someone else to turn the ignition on to help identify if the sound is coming from the boot or the dash.
If it's coming from the boot then its more than likely a tracker of some sort. I had one in mine when I bought it which beeped when approaching speed cameras.
I took a close look around the equipment in the boot to see if anything looked aftermarket, and first noticed a small speaker on right hand side and GPS / GSM antenna on the left. The wires disappeared behind the boot panels, so I removed the side panels and found a Smart Nav telematics device for fleet management with optional speed camera warning system.
The camera database is updated over the air which was great, but the down side was the charge for doing so - £265 / year Shocked. So I ripped** it out.
**Carefully removed
Gone - Range Rover Supercharged 2006
Post #78932 2nd Sep 2011 10:13pm
ric355
My tracker emits three beeps from what sounds like the rear left compartment. Interestingly it's three beeps when you have the tag on you, and five beeps when the tag is missing. So if it's the same system then the tag might be inside the car somewhere if you're not aware of having been given something. The tag is not credit card sized in my case; it's smaller and thicker (maybe 3-4mm thick) and is in a black plastic case.
Post #78933 2nd Sep 2011 10:23pm
andyboy
thanks guys i will try your suggestions and i'll let you know Thumbs Up
Post #78982 3rd Sep 2011 12:54pm
andyboy
since i posted last time its only happened once more but i noticed the word "prog" on the dash display
Post #79911 8th Sep 2011 5:39pm
So is it a beep or a bell (a spritely and very annoying "doioing") ? .
Post #79921 8th Sep 2011 6:13pm
andyboy
beeps and its beginning to get on my Censored mate
Post #80083 9th Sep 2011 3:19pm
does it do it on or near the hour...
Post #80085 9th Sep 2011 3:26pm
andyboy
no its not the clock mate
Post #80086 9th Sep 2011 3:43pm
simon1233
Rolling with laughter Rolling with laughter
Post #80088 9th Sep 2011 3:52pm
