![]() | Home > General > three beeps |
Sounds like you have a tracker fitted, search the forum, lots on this. .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35811 ![]() ![]() |
from memory i think its a tracker device bleeping, might be wrong though...
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
had the car nearly 2 years can't remember doing it before,and i know its not the clock as it didn't happen on the hour. |
have you come across a small credit card size fob...while cleaning the car.. V8 facelift Range Rover Autobiography 22" wheels.
unfortunately no |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Have a look in the boot and get someone else to turn the ignition on to help identify if the sound is coming from the boot or the dash.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
My tracker emits three beeps from what sounds like the rear left compartment. Interestingly it's three beeps when you have the tag on you, and five beeps when the tag is missing. So if it's the same system then the tag might be inside the car somewhere if you're not aware of having been given something. The tag is not credit card sized in my case; it's smaller and thicker (maybe 3-4mm thick) and is in a black plastic case. |
thanks guys i will try your suggestions and i'll let you know |
since i posted last time its only happened once more but i noticed the word "prog" on the dash display |
So is it a beep or a bell (a spritely and very annoying "doioing") ? .
beeps and its beginning to get on my |
does it do it on or near the hour... |
no its not the clock mate |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
