![]() | Home > Technical (L322) > car wont turn over! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
sounds like the battery..you may have lights etc but not battery power to turn it over... |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Yep, I would start at the battery.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
mine did this yesturday id put all my money on your battery |
killatomato Member Since: 15 Jul 2011 Location: Wirral Posts: 41 ![]() ![]() ![]() |
Hi guys it's happened again, so I called RAC. Guess what happens as soon as he arrives the thing fires up. Then we tried about 20 times and only 2/3 times it did not turn over. So it should not be the battery but a faulty part - lock barrel? Solenoid? |
Hello, anybody have any ideas? I really don't want to go to the stealers! |
Gearbox inhibitor switch?
still reckon its the battery....how old is yours ,if over about 3 years then its time to change.. ... - .- -.
The battery is less than a year old. Its been starting fine for the last day, even though I was doing stop/start journeys. |
ok then, in the words of homer, 'i dont know'. ... - .- -.
Poor earth to the starter, knackered starter, broken wire, inhibitor switch on gearbox, blown fuse, there are so many things that could cause this problem and only by working through some of the more common faults will you be able to eventually find the cause |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
My money would be on a battery too, mine used to do it if the car had been standing for a week or so. 2006 Mercedes CLS
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Mine does this occasionally, even though she starts fine after removing and re-inserting the key. |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
i had this problem too, it turned out to be a faulty module in the steering column 2002 td6 vogue, 06 supercharged facelift
Darrenmax, do you know what the module was?. |
