Home > Technical (L322) > Condensation in Rear Light
sms720
Hi
I am experiencing a small amount of condense in the offside rear light cluster - is it just from moisture trapped the last time a bulb was replaced or is this a common issue of a perished seal?
Is it fairly easy to remove the light cluster?
Thanks
Simon
Post #8057 26th Oct 2009 10:37am
It's a common issue on the earlier cars, mine has it too each time I wash it.
If your car is under warranty you cna get them replaced, there is no fix, you can't really dismantle them.
Removal is fairly easy:
Instructions in this thread: Good luck:
http://www.fullfatrr.com/forum/topic405.ht...ht+removal
http://www.fullfatrr.com/forum/topic60.html?highlight=rear+lights Discovery 4 HSE
1993 90 Tdi
Post #8058 26th Oct 2009 10:43am
sms720
So just so I understand you fully, it's a fault with the light cluster and a new one would sort the issue?
Regards
Si
Post #8069 26th Oct 2009 11:15am
Yes Discovery 4 HSE
1993 90 Tdi
Post #8071 26th Oct 2009 1:05pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
My 03 had this on the OS light.After years of putting up with it I drilled a tiny hole in each bottom corner.SORTED FOREVER!! If you have nothing nice to say,say nothing at all.
Post #8073 26th Oct 2009 1:21pm
sms720
That is what I am concerned about, buying a new one and it doing the same!
Do you know what causes the issue - is it just bad design?
Regards
Si
Post #8076 26th Oct 2009 2:59pm
Vogue
bad design, if you find a light cluster that doesn't do it then thats the exception. The P38's were even worse. Save your money and buy a tiny drill bit!
Post #8077 26th Oct 2009 3:30pm
sms720
Thanks all, seeing as I was thinking about buying a new one, I'll try drilling a hole first and see if that works
Post #8079 26th Oct 2009 4:50pm
