![]() | Home > Technical (L322) > Condensation in Rear Light |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
It's a common issue on the earlier cars, mine has it too each time I wash it.
sms720 Member Since: 20 Sep 2009 Location: Northern Ireland Posts: 33 ![]() ![]() |
So just so I understand you fully, it's a fault with the light cluster and a new one would sort the issue?
Yes Discovery 4 HSE
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
My 03 had this on the OS light.After years of putting up with it I drilled a tiny hole in each bottom corner.SORTED FOREVER!! If you have nothing nice to say,say nothing at all. |
That is what I am concerned about, buying a new one and it doing the same!
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
bad design, if you find a light cluster that doesn't do it then thats the exception. The P38's were even worse. Save your money and buy a tiny drill bit! |
Thanks all, seeing as I was thinking about buying a new one, I'll try drilling a hole first and see if that works |
