Home > Maintenance & Mods (L322) > Front seat removal
supershuttle
Front seat removal
Is it just the 4 bolts holding the slide rails down and a quick unplug of the electrics ? Geoff
Post #81076 13th Sep 2011 10:50pm
Googsy
Might be best to disconnect battery also just in case you forget to plug in one of the looms for seat airbag and your left with a fault light on . Cant advise on removal but nosey to know wjy you are removing seats? Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #81077 13th Sep 2011 10:59pm
supershuttle
Problem with rear door speakers apparently the wires chaffe under the front seats Geoff
Post #81078 13th Sep 2011 11:03pm
four bolts and the one for the seatbelt... if you dont put your keys in the ignition whilst the seat is removed you wont put the airbag fault light on... as suggested above, if you disconnect the battery you dont run any risk... hope this helps... Thumbs Up
Post #81081 13th Sep 2011 11:06pm
supershuttle
Thanks guys keys out battery disconnected it is. I think thats what's called belt and braces Geoff
Post #81084 13th Sep 2011 11:11pm
SteveMFr
Site Sponsor
You do have to leave the batt connected till you've undone the seat bolts as you have to drive the seat back and forth. Drive the seat back until you can undo the front bolts, undo, then drive the seat fwd again till you can get at the rears. Tilt the backrest fwd and you'll have a balanced package as small as it's going to get. Then undo the rears, disconnect the batt (Follow procedure! Wait for the nav to shut itself off!), disconnect the plugs under the seat and remove by lightly lifting the seat out the front door. Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #81236 14th Sep 2011 2:29pm
supershuttle
Thanks Steve,
I had been through the procedure in my head and realised that you need the battery connected initially then disconnected before meddling with the wires or disconnecting stuff. I assume that if an air bag fault code did register I could clear it with the IIDTool anyway. Obviously you have done this before, do I need to actually lift the seats out or can I just move them into the back.
I can't do it yet as I've lent my socket set to someone and I can't get it back until Monday Sad
Thanks
Geoff Geoff
Post #81330 14th Sep 2011 8:58pm
i've removed both front seats without dis-connecting the battery...made sure the car was in sleep mode and the key out of the ignition..no airbag warnings at all..
Post #81334 14th Sep 2011 9:06pm
SteveMFr
Site Sponsor
Geoff,
I've not actually had to repair speaker wiring - that was Christian and Patrick on Christian's RR - but if you look at the pics, they had to fold the carpet back to get at the wiring. You'll need to have the seat out to get that far.
The damaged wires are visible in the slot between the aluminum plate and the white plastic cable tunnel cover (just in front of the ratchet).
Stan,
Generally you can do all sorts of things w/o any damage. And Geoff can easily clear an SRS fault with the IIDTool. But by disconnecting the battery you know you're on the safe side. You can shut a windoze computer down by holding the power button for a couple of secs. And you can prob do this quite often w/o damage. But sooner or later you will have a problem. Disconnecting and reconnecting a battery takes only seconds (much less time than a shutdown/reboot of my silly computer takes). And an additional minute to reset everything from clock to seat mems to radio presets. And fixing a prob could potentially take much, much longer. I did this (auto electrics/electronics) professionally for several years. IMO it's not worth it. Wink
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #81349 14th Sep 2011 9:55pm
you are absolutely correct steve...battery dis-connection is the proper way to do it, i just found it quicker/easier to remove the seat without dis-connecting it..bad habits are hard to get rid of. Wink
Post #81350 14th Sep 2011 9:59pm
supershuttle
Don't sweat this boys, I will disconnect the battery - Health and Safety - and take the seat right out as you suggest Steve.
Stan,
I'm nervous disconnecting the battery but more nervous messing with wires when it's connected, moving the seats out is only to get at the aforementioned wires. Interestingly I had never noticed that the back speakers had stopped working (only the top ones) until the IIDTool told me they had and I checked by sticking my head in the back, it's obviously normally in the front - my head that is Very Happy
I actually found last time that disconnecting the battery is a sort of reset for some suff, a bit like rebooting a computer.
Last Orders beckons
Cheers Geoff
Post #81351 14th Sep 2011 10:04pm
geoff , dont forget to turn the steering wheel fully left ,then right after connecting the battery back up...... Thumbs Up
Post #81357 14th Sep 2011 10:17pm
Googsy
Sometime later .....Like I said disconnect the battery Laughing Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #81364 14th Sep 2011 10:47pm
supershuttle
googsy2 wrote:
Sometime later .....Like I said dsiconnect the battery Laughing
Thumbs Up Geoff
Post #81369 14th Sep 2011 11:21pm
