![]() | Home > Maintenance & Mods (L322) > Front seat removal |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
Is it just the 4 bolts holding the slide rails down and a quick unplug of the electrics ? Geoff |
Might be best to disconnect battery also just in case you forget to plug in one of the looms for seat airbag and your left with a fault light on . Cant advise on removal but nosey to know wjy you are removing seats? Present :2008 TDV8 HSE
Problem with rear door speakers apparently the wires chaffe under the front seats Geoff |
Thanks guys keys out battery disconnected it is. I think thats what's called belt and braces Geoff |
You do have to leave the batt connected till you've undone the seat bolts as you have to drive the seat back and forth. Drive the seat back until you can undo the front bolts, undo, then drive the seat fwd again till you can get at the rears. Tilt the backrest fwd and you'll have a balanced package as small as it's going to get. Then undo the rears, disconnect the batt (Follow procedure! Wait for the nav to shut itself off!), disconnect the plugs under the seat and remove by lightly lifting the seat out the front door. |
Thanks Steve,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35772 ![]() ![]() |
i've removed both front seats without dis-connecting the battery...made sure the car was in sleep mode and the key out of the ignition..no airbag warnings at all.. |
Geoff,
you are absolutely correct steve...battery dis-connection is the proper way to do it, i just found it quicker/easier to remove the seat without dis-connecting it..bad habits are hard to get rid of. |
Don't sweat this boys, I will disconnect the battery - Health and Safety - and take the seat right out as you suggest Steve.
geoff , dont forget to turn the steering wheel fully left ,then right after connecting the battery back up...... |
Sometime later .....Like I said disconnect the battery |
