![]() | Home > Maintenance & Mods (L322) > door handle removal |
W88DY M Member Since: 15 Sep 2011 Location: liverpool Posts: 116 ![]() ![]() ![]() |
hi all,
Don't exactly know , but have heard they can be a bit of a PITA to take off .. |
thanks any way mike
^^^^^^^ What AMD said , i have had the covers on my handles for nearly two year now , 5 minute job done …. |
did u have to get them sprayed ? |
No just bought the Black ones coz i changed all the bog standard brunel grey bits to black |
ok thanks for the info |
Has any one tried to take these off before ? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Hi, you need to remove the door card then undo the 10mm bolt 25mm back from the front of the inner black plastic handle holder, then remove a small black rubber grommet inside the door shut (behind the lock in drivers door and lock blank in other three) undo the torx head bolt and the lock cover will fall off in your hand. Undo the cable either at the handle end of the mechanism end and wiggle the handle... It should then come out... Hope this all helps, not too hard to do... Incidentally, the material land rover make the handles from is |
I think the covers work really well and are a perfect fit.
Thanks for all your help but I think I will go for the covers
