Home > Maintenance & Mods (L322) > door handle removal
W88DY M
United Kingdom 2003 Range Rover Vogue Td6 Oslo Blue
door handle removal
hi all,
can any one tell me how to remove the handles on my rr vogue
as they are a bit scruffy and in need of a paint
thanks Thumbs Up Thumbs Up Thumbs Up
Post #81605 15th Sep 2011 10:15pm
Don't exactly know , but have heard they can be a bit of a PITA to take off ..
Post #81607 15th Sep 2011 10:18pm
AMD
You could fit some covers instead. Check out ebay or Powerful UK. I understand they fit well. Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #81608 15th Sep 2011 10:21pm
W88DY M
thanks any way mike
if they are a pain in the a$$ to take off i might just buy some covers
Post #81609 15th Sep 2011 10:22pm
^^^^^^^ What AMD said , i have had the covers on my handles for nearly two year now , 5 minute job done …. Thumbs Up
This is what they look like on
Post #81610 15th Sep 2011 10:23pm
W88DY M
did u have to get them sprayed ?
Post #81612 15th Sep 2011 10:28pm
No just bought the Black ones coz i changed all the bog standard brunel grey bits to black Thumbs Up
Post #81613 15th Sep 2011 10:29pm
W88DY M
ok thanks for the info Thumbs Up
Post #81614 15th Sep 2011 10:30pm
W88DY M
Has any one tried to take these off before ?
Post #81637 16th Sep 2011 7:06am
Hi, you need to remove the door card then undo the 10mm bolt 25mm back from the front of the inner black plastic handle holder, then remove a small black rubber grommet inside the door shut (behind the lock in drivers door and lock blank in other three) undo the torx head bolt and the lock cover will fall off in your hand. Undo the cable either at the handle end of the mechanism end and wiggle the handle... It should then come out... Hope this all helps, not too hard to do... Incidentally, the material land rover make the handles from is Censored and even if you paint them you will find they may chip again! So if you do a web search for powerfull uk ltd, they do the handle covers in any painted colour and also chrome etc etc. I painted my first 2004 vogue set java black and soon realised the plastic material was to blame for the handles marking/chipping not the paint and fitted a set of their door handle covers which were on there for over four years before sale without one mark appearing!
Post #81651 16th Sep 2011 8:13am
I think the covers work really well and are a perfect fit.
They are cheaper and in stock at http://www.lrparts.net/
Post #81663 16th Sep 2011 9:13am
W88DY M
Thanks for all your help but I think I will go for the covers
Post #81688 16th Sep 2011 10:15am
