Home > Technical (L322) > Squeak
Dave ray
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Squeak
Squeaky suspension any ideas
Post #82388 19th Sep 2011 2:20pm
kill the mouse.. ... - .- -.
Post #82390 19th Sep 2011 2:28pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
not alot to go on but ill stab in the dark at front balljoints. 2004 black Vogue TD6
Post #82393 19th Sep 2011 2:35pm
Dave ray
I have only had it in the last 2 days little bit anoying is it a big job to fix
Post #82394 19th Sep 2011 2:39pm
letsavit2
go drive it and post spme more info, ie front left, when turning, over speed bumps etc. describe the sound better too. No one can be 100% over a forum but with more info we can tell you what to check 2004 black Vogue TD6
Post #82399 19th Sep 2011 2:44pm
ric355
If you have side steps it can be helpful to stand on them and bounce the car (not whilst driving I might add!!). You might be able to tell whether it is coming from the front or rear and possibly which side. Bit easier than when driving, where I find it tends to be harder to see where it's coming from.
Take it for a drive first to get everything hot; squeaks sometimes don't show up from cold.
Post #82405 19th Sep 2011 2:57pm
Dave ray
Thanks for the advice it does it when turning slowly and slowing down to stop it stopped for a day then came back I can only describe it as a squeak/clunk noise if that makes any sense
Post #82408 19th Sep 2011 3:08pm
Dave ray
Sounds like it's coming from the front left
Post #82440 19th Sep 2011 4:51pm
letsavit2
haunted house door = balljoint.
knock = roll bar link.
between say 70-90k they go. 2004 black Vogue TD6
Post #82515 19th Sep 2011 8:52pm
Dave ray
Mine just hit 105k is it a big job
Post #82528 19th Sep 2011 9:19pm
letsavit2
nope not a big job.
get it too a garage and on a ramp, normal cheap garage will do as its an easy job. 2004 black Vogue TD6
Post #82609 20th Sep 2011 2:55pm
Dave ray
Your not wrong £89 including vat thought my v10 touerag was temperamental these are in a different class
Post #82632 20th Sep 2011 5:24pm
stu
yes but these are cheaper and easier to repair than the Touareg!! the final straw for me was thick end of £2k to sort out the rear brakes on mine.
brakes for the FFRR along with most either items are cheaper and easier to source, you know you love it really.. Laughing Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #82695 20th Sep 2011 9:14pm
