Home > Technical (L322) > Easiest place to get to aerial cables?
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Having spent more time reading up on how to use my iPod than driving the car, I've concluded that my easiest short-term option is an FM modulator in the aerial cable. Used one of these before, not the greatest but it does work.
So I need to get to the aerial cable somewhere I can tee in. I think I should be able to findit in the LH (nearside) boot compartment? Here's a picture of mine:
Can anyone point me in the right direction please?!?
Also, will the nav DVD drive play DVDs onto the front screen?
Post #83447 23rd Sep 2011 3:25pm
simon1233
Not sure which is the tuner box, but would guess that it is the one with the FAKRA connectors for the ariel leads.
You can get adaptors which will allow you to add the input of a FM transmitter (converts FAKRA to standard old-fashioned connectors and back). I used to have a similar set-up in a 2004 MB E-Class estate. A £10 FM transmitter from Maplin then pushed the sound to the head unit. Aux in cable connected to the FM transmitter unit.
Benefit of this system was that it blocked out all other radio interference when turned on.
Post #83455 23rd Sep 2011 3:41pm
Martin
Site Admin
Perhaps you can use one of these?
http://www.disco3.co.uk/shop/index.php?act...oductId=34
Post #83456 23rd Sep 2011 3:42pm
Cappo
FAKRA???
Do you mean the box at the bottom with a pair in and a pair out? Does it have twin aerials? I guess it wouldn't matter which you used if so?
The box at the bottom says MOST on it along with various part numbers which I'd need my specs to read!
Post #83457 23rd Sep 2011 3:48pm
Martin
Site Admin
The pinky white-ish bundled pair is a MOST optical loop which you SHOULD NOT touch!
Post #83458 23rd Sep 2011 3:49pm
pretlove
i used to use an fm transmitor that just plugs into the bottom of the iphone and doesnt need to be wired into the car very simple and no messing about just plug and play....ill try and find you a link "RANGEISM WILL NOT BE TOLERATED"
Post #83462 23rd Sep 2011 4:03pm
simon1233
Just been and looked in the back of mine. Am not even certain if the radio tuner is back here? Possibly part of the head unit?
The unit at the lower right of your photo has 4 ariel lines going into it and possibly is the TV tuner (is the TV tuner and radio combined on these cars??). Then to the lower left you have the harmon kardon amp and the TMS unit in front of it. Couldn't see anything that was obviously the radio tuner Sad
Using an FM transmitter that plugs into an iPod directly is always disappointing in my experience as they aren't sufficiently powerful enough to block out interference from other broadcasters. Still I haven't had to use one for several years so maybe they've improved.
Simon
Post #83467 23rd Sep 2011 4:10pm
Cappo
Simon
Mine's a 2006 Facelift (Jag) model but it does seem that the 2006 fell into a gap between earlier specs and MY07 models. I was under the impression that the FM aerial cables were in the back, but.....
Is it easy to remove the HU?
Post #83472 23rd Sep 2011 4:30pm
Cappo
Quick bump for this as I'd like to have a crack later on today!
Post #83605 24th Sep 2011 9:39am
Cappo, try the drivers side boot panel as im sure there is one in there.
I'll try and pop out in a little bit when i get a break and have a look at mine as most of my boot trim is out anyway Smile
Post #83610 24th Sep 2011 10:33am
Re: Easiest place to get to aerial cables?
Follow the black and white wire in the top right of your picture up into the trim and you should see a box there, 'i think' this is the aerial cable. Test it by having the radio on and pulling it out as the connector looks the right size and shape for it Smile
Post #83617 24th Sep 2011 11:21am
Cappo
Good work! I think that's it - Googled the P/N on the amp and it comes back as radio amp (there's another nearby which is TV amp). Thanks for that.
Now to find some suitable connectors....
Post #83620 24th Sep 2011 12:31pm
