![]() | Home > Technical (L322) > Easiest place to get to aerial cables? |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Not sure which is the tuner box, but would guess that it is the one with the FAKRA connectors for the ariel leads.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Perhaps you can use one of these?
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
FAKRA???
The pinky white-ish bundled pair is a MOST optical loop which you SHOULD NOT touch! |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
i used to use an fm transmitor that just plugs into the bottom of the iphone and doesnt need to be wired into the car very simple and no messing about just plug and play....ill try and find you a link "RANGEISM WILL NOT BE TOLERATED"
Just been and looked in the back of mine. Am not even certain if the radio tuner is back here? Possibly part of the head unit?
Mine's a 2006 Facelift (Jag) model but it does seem that the 2006 fell into a gap between earlier specs and MY07 models. I was under the impression that the FM aerial cables were in the back, but..... Is it easy to remove the HU? |
Quick bump for this as I'd like to have a crack later on today! |
Cappo, try the drivers side boot panel as im sure there is one in there.
Follow the black and white wire in the top right of your picture up into the trim and you should see a box there, 'i think' this is the aerial cable. Test it by having the radio on and pulling it out as the connector looks the right size and shape for it ![]() |
Good work! I think that's it - Googled the P/N on the amp and it comes back as radio amp (there's another nearby which is TV amp). Thanks for that.
