![]() | Home > In Car Electronics (L322) > TV Upgrade |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Hi All,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
ebay listing gone ashley.. ... - .- -.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Assuming yours is not a touch screen, all you would need is one like this:
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Ash's link is not right, it's been copied from somewhere else with the dots (...) in the middle of it, which breaks it. Now fixed. |
Thanks Martin |
Thanks Martin.
Ahwell |
tanertimur Member Since: 17 Sep 2011 Location: London Posts: 90 ![]() ![]() ![]() |
Iv got the gvif interface in my touch screen system, With same freeview tuner as mentioned above, works for me. I do have to upgrade areial or find a wAy to connect to car areial thou for better picture On the move. Range rover td6 54 reg touch screen |
Reformed - Help required if you don't mind...
Thats the same freeview unit as I have.
Yep - I don't even get the menu on the screen - just a black screen saying mute at the bottom when I switch it to AV..!
As long as the yellow AV ouput from the Freeview box is connected to the video in on the AV lead you should see something.
Have you got a portable dvd player or similar just to check you AV input lead is correct? Reformed |
I'll check that tonight to try to narrow the issue. Thx
