Home > Technical (L322) > Detachable Tow bar won't detach
Andy
Now Im a fully paid up member of the caravanning fraternity, I've refitted my towbar. When I bought the car, it was fitted, but I couldn't remove the towbar, so I unbolted it from its square section housing and fitted the square blanking plug. I left the towbar to soak in WD-40 overnight.
I recently refitted the whole thing and used the key to unlock it. The twist-knob turns and the towbar goes loose, but still won't drop out! If I let got of the twist-knob, it tightens up, so somethings releasing inside.
Short of warming it up with oxy-acetylene, I can't think of any way of getting it off. Anyone offer any ideas? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #87045 12th Oct 2011 7:57pm
have you tried pulling the knob out when you turn it.. ... - .- -.
Post #87046 12th Oct 2011 8:05pm
The spring loaded ball bearings that lock the tow hook into the receiver aren't releasing fully due to corrosion / non use.
Prise the plastic bung out of the top of the receiver and pour wd 40 in from there and keep working the knob. Hopefully the ball bearings will release eventually.
Not sure heat would actually do anything to be honest.
Post #87048 12th Oct 2011 8:09pm
Turn the key, pull knob out, twist knob.
Post #87050 12th Oct 2011 8:11pm
Andy
Tried that- knob does pull out slightly, but towball still won't come out. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #88590 23rd Oct 2011 5:08pm
T24RES
Big ball bearing has probably stuck, lube like what the man said. Fingers crossed. Thumbs Up
Post #88591 23rd Oct 2011 5:17pm
noddy , bang it with a hammer to loosen the 'ball catches' inside and turn and pull the knob while you are doing this.. ... - .- -.
Post #88593 23rd Oct 2011 5:30pm
Re: Detachable Tow bar won't detach
scarey wrote:
have you tried pulling the knob out whaen you turn it..
I confused the FFRR forum with another I post on and now I've done myself an injury.
Post #88609 23rd Oct 2011 6:48pm
Laughing ... - .- -.
Post #88621 23rd Oct 2011 7:54pm
