![]() | Home > Technical (L322) > Dead TD6 |
Before someone else jumps in how good is the battery?
Battery would be the first thing to check, closely followed by the secondary fuel pump under the car, then the fuel pump in the tank.
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Hi guys thanks for replies this is where im at battery brand new no pumps running at all so jumped a wire from battery to aux pump by tank both pumps started to run and fuel at engine now but no start its as if the power to pumps management ect cut ?????? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Just a thought, is anything electrical on the car working?
Hi Yes all electrics work but have found the issue the rear fuse box has no power so i have rig a cable from battery to rear fuse box and all work . finding the break may be difficult |
I would imagine the cable that serves the rear fusebox is fused. Find the fuse, find the fault? |
Your spot on rave shows a link 5 100 amp but where is this link its not in glovebox fuse box |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
If it was the fuel pump (secondary) the symptoms are stuttering and loss of power but still driveable. Discovery 4 HSE
