Home > My Range Rover > got one at last
filthyliam
got one at last
Yey1
after 5 months of looking finally got one just how I wanted non window tinted, non chromed, std looking 4.4 v8 Black with Ivory leather!
just a few points which others may have encountered
how good are chips away etc in the mobile bodywork repair world I have a corroded alloy to repair and a couple of minor scratches on body and bumper anyone used them ?
one key remote doesnt work light flashes but no opening etc was gonna get another battery but seen a place on fleabay that does a new body and keycut for about £12 or, should i go to the dealers (safer) and get a new one if its not much more as the spare is a bit shoddy looking anyway
just need to sort out my I phone connectivity now its not hooking up !
Post #87597 15th Oct 2011 9:23pm
On the key front try a new battery then re-sink with the car. Have a search as the process is well documented. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #87607 15th Oct 2011 10:00pm
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
I look at it this way. Those Ebay sellers ask you to send them your key code, or spare key so they can cut you a new one... Now they have your key and your address, and you have... nothing if your unlucky - just an empty driveway where your FF once stood.... There is a seller there somewhere that doesn't ask for your key, they will send you a blank, which you can have cut else where, then you just slip the circuit board in from your old key and do a re-sync.
As mentioned though, if the LED is coming on, then you may just need to re-sync your old one.
Post #87818 18th Oct 2011 3:57am
filthyliam
thanks for the info guys just ha d a look for re sync stuff but cant seem to find out how to do it could this be done by main dealers do you know ?
Post #88008 19th Oct 2011 3:20pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
It could but will cost Censored loads
Try these guys:
http://www.independentlandroverservices.co.uk/
Post #88027 19th Oct 2011 5:50pm
simon1233
You could try the info in this thread
http://www.fullfatrr.com/forum/topic3713.html?highlight=resync
When my car had the alternator replaced it forgot my main key (probably because i sent the car away with Landrover assist with just the spare), the service manager reprogrammed both keys back in in less than 2 minutes in the car park using the method in this thread
Post #88040 19th Oct 2011 7:42pm
filthyliam
thanks for the info just to clarify if i start by changing the battery to see if its that do i need to re sync is there a way of telling if the battery is going eg will it flash differently or beep etc ?
Post #88068 19th Oct 2011 9:24pm
