![]() | Home > My Range Rover > got one at last |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
On the key front try a new battery then re-sink with the car. Have a search as the process is well documented. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155
I look at it this way. Those Ebay sellers ask you to send them your key code, or spare key so they can cut you a new one... Now they have your key and your address, and you have... nothing if your unlucky - just an empty driveway where your FF once stood.... There is a seller there somewhere that doesn't ask for your key, they will send you a blank, which you can have cut else where, then you just slip the circuit board in from your old key and do a re-sync.
| filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 82
thanks for the info guys just ha d a look for re sync stuff but cant seem to find out how to do it could this be done by main dealers do you know ? |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075
It could but will cost |
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
You could try the info in this thread
thanks for the info just to clarify if i start by changing the battery to see if its that do i need to re sync is there a way of telling if the battery is going eg will it flash differently or beep etc ? |
