Home > Maintenance & Mods (L322) > Fitting Front Mudflaps
Googsy
Right chaps got the brackets and removed lower panel under sharkfin grills. Although there are two holes in the bracket there is only one on the fixing location. I lined up the bracket and have drilled a second hole and fixed with a screw . Fitment is solid but the fixing points that sit into the front wheel arch seem to be in too far on the bottom. Am I right in thinking I can bend these so can align mudflaps properly and fit. It doesnt help that none of the screws actually fit but ive overcome this . Please advise. Thanks.
I took this pic from RRUK's gallery and I think pre 2007 models had asecond hole as below
 Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #86723 11th Oct 2011 6:52pm
Something rings a bell here, but I can't remember why.
I'll take a look at the weekend if it doesn't snow and report back! Got - 2017 SDV8 Autobiography in Loire Blue
Post #86823 11th Oct 2011 10:46pm
Googsy
Thumbs Up appreciate that Alan Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #86825 11th Oct 2011 10:49pm
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
The bottom hole is bigger than the M6 (i think) that bolts through, did you have the bracket snug with the square aperture before you drilled the new top hole?. The pressed lip on the bracket fits into the aperture like shown in the picture you posted up. If its not as shown perhaps it isnt lined up properly?
I just fit some a week or so ago and they lined up perfectly this way.
You have to slide some clips over the bracket also but mine were perfect on a 2007.
Post #87226 13th Oct 2011 3:27pm
Googsy
Carlos thanks for your response yes it defo lined up correctly I wouldnt have drilled a hole in my beloved rangie otherwise. Would love to see some pics of your if i could showing bracket and clips etc. I have clips but despite lining up i reckon i need to use a pliers to bend into place as they seem too far rescessed into arch. Additionally how did you facilitate the fix point underneath as i have a plastic screw there that im unsure what to replace that with . Much appreciated. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #87316 14th Oct 2011 1:05am
i found this relating to the RRS but it might give you an idea to how to get over your problem
Post #87320 14th Oct 2011 8:04am
Googsy
Thanks Scarey I found that too but fitment is completely different on the FFRR unfortunately. I'm surprised no one has had the same issues as me to be honest as its not a straight forward job and im quite good at DIY. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #87333 14th Oct 2011 9:52am
i fitted mine on my 2005 with no issues at all, i cant see your 2008 being that different..i just used self tappers , 2 into the inside arch and 1 underneath, didnt use any bracket's though... ... - .- -.
Post #87337 14th Oct 2011 10:00am
I fitted front mudflaps to my car recently, followed the instructions to the letter and didn't have to bend the mounting bracket. I found it fitted perfectly.
I thought the fitting instructions were really good.
The only awkward bit was trimming the plastic mudshield neatly to fit around the mounting bracket and not leave gaping holes when re-fitted.
Personally I think LR should have supplied a template as part of the kit to allow you to trim the mudshield correctly.
Post #87341 14th Oct 2011 10:10am
Googsy
Aha
I did not getting fitting instructions did not realise plastic arch trim had to be trimmed might be of help thanks Thumbs Up
What did you use to fix the bottom part of flap underneath ? Was it the plastic screw that was in the hole?
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #87345 14th Oct 2011 11:05am
The instructions didn't indicate any fixing underneath but I decided to use a stainless self tapping screw thro each mudflap into the plastic cill trim for a bit of extra security.
I'm amazed you managed to fit them without instructions and templates for the fixings. Smile
Just remember to refit the mudshields before finally fitting the mudflaps, a very sharp blade is required.
Post #87348 14th Oct 2011 11:39am
Googsy
Finally got these fitted today harder than it looked thankfully I realised half way through I needed fitting brackets anyway job done thanks to all for advice Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #87774 17th Oct 2011 5:54pm
