![]() | Home > Maintenance & Mods (L322) > Oil change for gear box |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
its debatable whether an oil change actually does any good or not...how many miles has the box done? if its going to fail then most go around 80/100k....personally, if its working ok i would leave it alone.. ... - .- -.
Dave ray Member Since: 19 Sep 2011 Location: Wirral Posts: 92 ![]() ![]() ![]() |
It's got a few on it 107k full main dealer history trying to find one with lower miles on but the ones I did see where not in the best condition but then I found mine high miles but looked after and a clean car |
there's loads of opinions re this on the forum dave, best have a read and get an informative view.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
If you do decide to change the oil and I personally would, you need to change the filter as well and then change the oil again in a couple of weeks.
drain the sump, and refill with fresh ATF, run for 5-10 minutes and drain again, remove sump and change filter, refill with fresh ATF and if you are really keen you can drain and refill the sump for a third time |
ssgall Member Since: 05 Dec 2010 Location: North East Posts: 35 ![]() ![]() ![]() |
Bought my latest FF this time last year with 93K, changed the gearbox oil (oil was black). Gearbox has just failed at 96K. From everything I have read if the oil hasnt been changed at about 50K, when Landrover should have recommened changing it, its only a matter of time before failure, average seems to be around 100K. Opinion is divided on wether its a good thing or not to change once the motor has done, or approaches higher mileages. For what its worth I believe lubrication is good and would do the same again.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
so you changed the oil and 3k later the box blew.....
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
yes, it does make you wonder if draining the oil empties the galleries, thus causing it to run momentarily dry - thus goosing the box a few miles later! maybe thats why LR say sealed for life...perhaps they knew there was an issue with draining and refilling. Afterall, its not in their or a LR main agents interest to skimp on servicing or do themselves out of service items by advising sealed for life without good reason... |
Surely the damage would be done when it was first built and filled if that was the case |
it could depend on how its filled and primed at the factory, and if this specific process is repeated when the box is drained and filled. |
filthyliam Member Since: 01 Aug 2011 Location: Lincolnshire Posts: 82 ![]() ![]() |
does anyone know how to check oil level in the gearbox AFTER its been changed ?
you fill up until it overflows.
Cheers scarey simple as ! |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
"You fill it up until it overflows - at the right temperature" |
