Home > For Sale & Wanted > Drivers Side A-Pillar Trim |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Have a look under your side sill, is the leak on the side the air suspension reservoir is fitted? If so, we have found the tube from the sunroof is sometimes pinched by the air reservoir... The facelift FF has a larger reservoir than previous model, hence the problems...
29th Oct 2011 10:02pm |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 |
Cheers Craig, i did crawl under and have a look but cant see anything even resembling a drain hose.
29th Oct 2011 10:59pm |
I'll put a small bet on with you its the drain tube... Have a good look, we've done approx 15 2007 onwards FF's with water leaks all down to the air reservoirs...
30th Oct 2011 12:02am |
Well Craig looks like your right..
30th Oct 2011 12:13pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
lets have some photos V8 facelift Range Rover Autobiography 22" wheels.
30th Oct 2011 6:24pm |
Dave - Will take photo's tonight when i get home.
31st Oct 2011 1:27pm |
