![]() | Home > For Sale & Wanted > Drivers Side A-Pillar Trim |
Have a look under your side sill, is the leak on the side the air suspension reservoir is fitted? If so, we have found the tube from the sunroof is sometimes pinched by the air reservoir... The facelift FF has a larger reservoir than previous model, hence the problems...
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 ![]() ![]() ![]() |
Cheers Craig, i did crawl under and have a look but cant see anything even resembling a drain hose.
I'll put a small bet on with you its the drain tube... Have a good look, we've done approx 15 2007 onwards FF's with water leaks all down to the air reservoirs...
Well Craig looks like your right..
lets have some photos |
Dave - Will take photo's tonight when i get home.
