![]() | Home > Technical (L322) > Park Heater fault - help needed... |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Right, I've got my IIDTool and plugged it in and read the HVAC fault code...
Update.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
Probably being stupid but doesn't the temperature need to be pretty cold before the Fuel Burning Heater fires up? 2012 5.0L S/C
I did look this up.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
i think the outside temperature has to be below a certain level before the FBH kicks in, and not the internal temp... ... - .- -.
Yes, sorry I wasn't clear. I meant the "Outside Temperature" as displayed on the cabin screen, has to be 16 degrees or less, which it was so I;d expect the heater to start.
Mine has been working at temps for the last few months when i try it, as even when the temp is above the fans kick in to air cool the cabin or vent to atmosphere, the heat that can build up inside the ffrr |
TBH I don't even know where the heater is. It's buried somewhere in the bowels of the engine bay. The Disco one is easily seen and accessible... Graham
rayc Member Since: 13 Sep 2011 Location: deal, kent Posts: 105 ![]() ![]() ![]() |
Possibly the glowplug?
How do I tell if it's working... especially as I can't find the FBH... |
have you browsed this graham
Yes, have tried that, defo no gases.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Been looking at this for a friend with an X5. You can put power to pin 1 on the connector and that will fire up the heater to make sure it's working. They quite often seize or something as they aren't used that often. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
claud Member Since: 15 Apr 2009 Location: Godalming Posts: 103 ![]() ![]() ![]() |
My FBH on the 2007 FFRR Vogue SE failed last winter during the really bad snow in November.
