![]() | Home > Technical (L322) > Help! Engine fail safe mode on and rough running 4.4V8 |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
How new is the batt? Could be a load of issues. Where are you as there might be someone local who can read your codes. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3273 ![]() ![]() ![]() |
Am in Fareham, Portsmouth (nr M27 J11).
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Engine in fail safe mode will read a fault as throttle position not set or out of range.
Thanks. Will try the accelerator trick. Its not the battery as it was tested and gave over 12.4v. I also have a back up connected in the boot! |
I would also go down the batt route. These cars chew batts for fun. Not 100% sure but I think the amps is the more important thing. Did they just test the voltage across the two terminals? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35861 ![]() ![]() |
testing the voltage will probably bring up 12.4 volts but you need to have a discharge test done on it where they put a amp load on the battery..
Stan, it's Dan_1984_uk's old car. He put a connected battery in the sunken box to the right of the boot where the tow bar normally goes. This was to counteract the drain that seemed to affect so many owners.
that makes sense then.. |
