![]() | Home > Maintenance & Mods (L322) > First time rotary polisher advice required - WITH PHOTOS :-) |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Hi Chaps,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Justin, best to get this done by the professionals my friend... You can cause hundreds of £sss of damage if you get it wrong...
I've tried removing the swirls by by hand and it looks great for a week or two but the swirls soon come back |
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
You could get a quote form these guys:
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
Hi Justin,
Hi Justin
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Have you looked at the Wiki on detailing to bone up before a purchase?
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Anothern |
Luckyluciano Member Since: 29 Oct 2011 Location: Wiltshire Posts: 121 ![]() ![]() ![]() |
If you can stretch a little this is a much better machine, quieter and with better bushes that last longer; http://www.cleanyourcar.co.uk/machine-poli...d_806.html As for pads go for either 3M (yellow & blue) or CG Hexlogic (White, blue & black) My personal favourite polish brand is Menzerna. Great polish as long as you work it properly and best for me you can use it in direct sunlight. After that I would use something like Poor Boys glaze, either Black Hole or White Diamond depending on the colour of your car. Lastly the LSP. You have hundreds of choices and all act/last slightly different from one another and for me it all comes down to personal preference. If your ever near Swindon and would like some tips feel free ![]()
Lucky Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 ![]() ![]() ![]() |
Yep as already stated if working by hand it's always best to try to hide the defects instead of correct them it's a thankless task. SRP is a great at it and readily available off the shelf. There are better products IMO though and can be bought easily on line. If you want to use a machine again as above I would recommend buying a da. A rotary is dangerous only with the untrained, as is a da but much less so. I would recommend getting a menzerna trial set, a finishing pad and some surbuf pads. Try a finishing pad with a finishing polish and if that's no enough go to the surbuf pads and work up through the polishes until you get the desired results, then refine with finishing pad and polish. The beauty of the surbuf pad is it can cut like a b1tch if needed, or not with a weaker polish but always finishes fantastically and like other names producing the newer style (mf) pads these don't need masses of pressure to get correction thus meaning the pads themselves last much longer. I still turn to these pads in times of need if the rotary is just not playing (on sticky paints etc). Take your time and read lots. And most of all enjoy it that's the important thing after all |
Thanks chaps,
Da is the oscillating one you speak of. Word of warning, the spin doctor is crap. Better with a high quality da IMO. If you want a cheaper style rotary look towards a silverline. With the hex pads, not to get boring, but there are so many colours as they use different foams. Some are closed cell some are open. I would recommend black for finishing, white for one step polishing and green for moderate swirl removal. After that yellow or orange cut pretty hard. Srp is not a machine polish and although some use it to good effect it really isn't the best. Go with "proper" machine polishes, either a menzerna bundle as I suggested or my fave pair of meguires 105 and 205. They are epic. But I really think a da is the way to go it's a much more versatile machine |
You'll want to go with 5.5". These are much more forgiving by creating much less heat but you still have to be very careful.
The larger the pad the more heat is created with the rotary due to increased friction. The reality is you need all sizes of pads, from car to car I will use 3 to 4 differing sizes for various shapes and contours. Yes you are right a da can take much much longer but honestly if time is a concern when perfecting your own car I really think it's time to give it to a pro. Nothing good ever came from rushing when detailing. Alright I am biased lol and spend hours but IMHO it's better as an a mature to take time and get a panel at a time done to your satisfaction, protect it and move on. Get the car completed in your own time, second coat of lsp et voila. Sped should NEVER be a factor when using a rotary that is where accidents happen. Plus, and again this is only my opinion, but I don't think you should ever do any machining, let alone with a rotary, without taking thorough paint readings. Hense why I still use my da regularly, great on bumpers for keeping heat down, great on sticky paints, less aggressive on unknown paints if you have them and a better finish can be achieved with less effort by a novice. It is an alround more versatile machine. That said, whatever you do, just don't get the spin doctor ![]() |
