Home > Technical (L322) > Yet another gearbox question.
Johnte
Is this a sign of impending doom.. Big Cry
For the last week first thing on a morning the RR starts straight up as usual, into gear fine with no hesitation - all nice and smooth. Then I drive down the road for about quarter of a mile slightly downhill, changes up fine - but then come to 'T' junction and the gearbox does a noticeable CLUNK down into low gear, rather than a nice smooth change..
Rest of the day, even after stop and re start all is smooth with no problems at all Confused
Is this the beginning of the end Big Cry Big Cry
Post #91002 8th Nov 2011 1:33pm
this is fairly common and i get it now and again...mines a 2005 as well ... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #91008 8th Nov 2011 2:23pm
ssgall
United Kingdom 2003 Range Rover Vogue Td6 Buckingham Blue
Mine recently failed and didnt have that symptom.
my symptoms were:
1. Hesitation selecting gear at low throttle openings, worst cruising at about 45 mph, but also when coasting slowly. (12 months prior to failure)
2. Slow to pick up drive from first start/cold, to the point of rolling backwards. (about 2 weeks prior to failure)
When it finally went: loss of drive, extreme clutch slipping and managed to limp home.
Didnt experience any clunking so you may be ok 2003 Vogue TD6 - Adriatic Blue - 2010 Facelift & 2010 20" wheels
1996 90 Tdi soft top gone
2003 HSE TD6 gone
2005 RRS TDV6 HSE gone
2007 Vogue SE TDV8 gone
Post #91025 8th Nov 2011 4:44pm
RRPhil
@ Johnte & scarey
I wondered if you were getting full engine braking in gears 3, 2 & 1?
Clutch pressures during overrun /rollout shifts for gears 3, 2 & 1 (i.e. for the low/reverse clutch, the 2nd coast clutch and the overdrive clutch) are modulated by the low pressure control valve.
This valve can wear badly (the ‘soft’ valve block problem) & allow regulated fluid to exhaust, causing harsh overrun/rollout downshifts.
Phil
Post #91164 9th Nov 2011 11:24am
whats the cure for this then phil.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #91167 9th Nov 2011 11:34am
Johnte
Thanks Phil.. You obviously know what you're talking about Thumbs Up
Would this only show when oil was cold? i.e only on first downchange of the day.
Can anything be done about it, or is it just wait until it gets worse - then new box Big Cry
Post #91168 9th Nov 2011 11:37am
RRPhil
What mileages do you guys have on your transmissions?
In my view, the golden rule with an L322 GM 5L40-E transmission is frequent fluid & filter changes (using only Texaco Texamatic 7045E and a genuine Filtran filter) to minimise - but unfortunately not totally prevent - valve block wear.
The renewed fluid viscosity resulting from a fluid change could buy you some more time if the wear process was already well underway. Sonnax supply kits for the 5L40-E to refurbish worn spools/bores in the block, for example for the low pressure control valve :
The problem is that if one valve has started to leak/crosstalk as a result of wear then the chances are that the rest may not be far behind. You’ll know when the situation is about to be terminal because the torque converter lock-up clutch will wear through its lining (through reduced control pressure) and dump a load of metallic debris into the fluid (which you can check for when you’re doing a frequent fluid change!). Sorry, did that all come across as a little pessimistic? Smile
Johnte, thinking about it further this seems an unlikely explanation for a one-off event when the transmission is cold (because the spool valve should be less likely to leak as the fluid viscosity is at its highest). 2-1 rollout shifts should be seamless as the engaging element is a mechanical sprag & not a clutch. Might it be the 3-2 shift that clunks?
Phil
Post #91188 9th Nov 2011 1:07pm
Johnte
It could be 3-2, as it's just when slowing down for first junction of the day (rest of the day it's fine)
Does that make a big difference in the diagnosis ?
Post #91207 9th Nov 2011 2:38pm
bozmandb9
Mine does this too, it's also a 2005. So far as I'm aware it's a software fault, and can be fixed with a re-flash of the gearbox ecu which costs around £100 or so.
It's a known problem, even when journalists were test driving the '06 model they commented on it, and to be honest it's a disgrace that LR don't just offer a free rectification to afflicted cars.
I got it fixed on my previous car but haven't bothered so far on the new one. Range Rover-less at the moment - Pining!
Post #91214 9th Nov 2011 3:00pm
RRPhil
Can I just check that we're talking about the same transmission?
The ZF 6HP26 unit ('06MY onwards - petrol and '07MY onwards - diesel) certainly had a problem with 2-1 rollout shifts which could be rectified by reflashing the ECU firmware.
I believe we're discussing the 5-speed GM 5L40-E unit used in the TD6.
Phil
Post #91221 9th Nov 2011 3:24pm
Johnte
Mine's a 2005 (2006MY) TD6
Post #91230 9th Nov 2011 4:23pm
bozmandb9
Well clarified Phil, mine's a 2006 MY S/C. Range Rover-less at the moment - Pining!
Post #91232 9th Nov 2011 4:50pm
@phil, i had a recon box at 116k and now its 126k and i've noticed that the little lights on the console [by gear lever] sometimes dont light when in that gear especially the 'd' one.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #91235 9th Nov 2011 4:55pm
So what's "frequent" for frequent oil and filter changes? .
Post #91244 9th Nov 2011 5:21pm
RRPhil
If it were mine, I'd drain & refill every 20k miles (which will replace about half of the fluid) and replace the filter every 40k miles. I emphasize that this is just my personal opinion.
Phil
Post #91282 9th Nov 2011 9:16pm
