![]() | Home > Technical (L322) > Yet another gearbox question. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
this is fairly common and i get it now and again...mines a 2005 as well ... ... - .- -.
ssgall Member Since: 05 Dec 2010 Location: North East Posts: 35 ![]() ![]() ![]() |
Mine recently failed and didnt have that symptom.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
@ Johnte & scarey
whats the cure for this then phil.. ... - .- -.
Johnte Member Since: 23 Aug 2010 Location: North Yorkshire Posts: 744 ![]() ![]() |
Thanks Phil.. You obviously know what you're talking about |
What mileages do you guys have on your transmissions?
It could be 3-2, as it's just when slowing down for first junction of the day (rest of the day it's fine)
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Mine does this too, it's also a 2005. So far as I'm aware it's a software fault, and can be fixed with a re-flash of the gearbox ecu which costs around £100 or so.
Can I just check that we're talking about the same transmission?
Mine's a 2005 (2006MY) TD6 |
Well clarified Phil, mine's a 2006 MY S/C. 2012 SDV8 Vogue SE |
@phil, i had a recon box at 116k and now its 126k and i've noticed that the little lights on the console [by gear lever] sometimes dont light when in that gear especially the 'd' one.. ... - .- -.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
So what's "frequent" for frequent oil and filter changes? .
If it were mine, I'd drain & refill every 20k miles (which will replace about half of the fluid) and replace the filter every 40k miles. I emphasize that this is just my personal opinion.
