![]() | Home > Technical (L322) > "rear water ingress" |
as long as you fit the 'shedder' and maybe use the a/c ,then you will be ok.. ... - .- -.
The water ingress is an easy fix, you need one of these........ |
Or in some cases one of these might be useful
Matt@obsidian Member Since: 29 Oct 2011 Location: Greater Manchester Posts: 70 ![]() ![]() ![]() |
Lol sounds fun in the freelander. Yes I was told it was a seal around the boot but I can't help think they are just finding a job to do without really knowing. Time will tell. Keep us posted Range Rover 4.4 V8 Autobiography Mustang Mach 1 (1971 in grabber green) Honda civic 2.2 diesel VW crafter with ICE |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
My 2002 TD6 had this problem. I traced the water ingress coming in from the bottom left hand corner of the boot where there are holes in the panel at the rear.(Too dark for photos but will try tomorrow.) I have stuffed a water absorbing rag in the hole for the time being but am looking at putting a lip in place to stop water dripping down into the well. I think it may be the rear wash wipe as it doesn't come out of the wiper onto the screen. |
Someone else has said the same thing about the wiper. Pictures would be a help to all cheers ![]() Mustang Mach 1 (1971 in grabber green) Honda civic 2.2 diesel VW crafter with ICE |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I've just noticed that I've got some of the dreaded water ingress - I have just been out looking and it appears to be coming in from the same place as you refer to - the bottom left hand corner of the boot around the area of the big bolts for the rear bumper.......I can't really see exactly how it's getting in though. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Dried it off and then washed the car - no obvious signs of water when hosing. I then took the car for a drive and came back and checked again - traces of water right at the back of the boot in the double skinned panel and a trickle from there into the tyre well.
There is a gasket between the bumper and the bodywork where the bolts go through, it might be leaking there |
Well I reckon its either the bumper brackets or the boot seal.........funny how it has just started leaking...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Here are some pics of where the water is coming in - the bottom left hand corner of the boot.
Very heful dolphinboy thank you Range Rover 4.4 V8 Autobiography
kanajobe Member Since: 12 Jun 2011 Location: Bristol Posts: 8 ![]() ![]() ![]() |
Hi
Dolphinboy, thanks for the pics, that is exactly the same as my issue - coming in through that hole.
