![]() | Home > Technical (L322) > Whats the easiest way to get a secondary key for my pre-05 |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Buy a second hand bmw key, and buy a shell with a blank blade (both on ebay). Get the blade cut to match your car, and take the innards from the secondhand key, and insert in the shell. Hey presto! 2012 SDV8 Vogue SE |
arrr, not quite that easy, yes the above post is correct but you will need it to be coded, now range rover wont code a bmw key unless you know some one, the pre 05 range rover key uses a Phillips PCF7930AS Transponder chip
Shropshire lass Member Since: 03 Oct 2011 Location: Shropshire Posts: 58 ![]() ![]() ![]() |
I too had this problem, I went down the main dealer route. However it's definitely worth phoning a few to compare prices as I found they varied quite alot. Also they all charged different amounts to then code the keys . I know there is a means of coding them yourself but when youve just bought a new one you want it to work! |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Can it be done remotely or will the vehicle need to be present?
magicbob Member Since: 03 Jul 2011 Location: Perth Western Australia Posts: 157 ![]() ![]() |
I purchased 2 new blanks from the bay of fleas, had the key cut here in Perth WA, inserted the old electronics.....yew bewdy!!!worked first time, no problems.
The car would need to be present to code a brand new key I believe. however it may be possible from some of the articles I read to code the key yourself . Think it depends on vehicle age. I'm sure someone more learned will appear to help you. |
Programming a new Key
As above! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6431 ![]() ![]() |
So exactly what kind of secondhand BMW key will pass muster in the coding process? Anyone actually done it? Pics? (not picks |
Hold on |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
When I asked for a new key at the dealers, I was told that it's delivered pre-cut and pre-programmed, with the info taken from the vehicles chassis number held at LR. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
When I got my new key it was ordered by a non landrover dealer . Key was coded into car MY2008 using an Autologic that my Indie had took about 2 mins. Present :2008 TDV8 HSE
yes i was told that they can programe and cut a key from your vin number but if for any reason you have had a lock change it wont fit and they will not give you your money back, it wold be nice to find some other then the dealer to get keys dome V8 facelift Range Rover Autobiography 22" wheels.
