|  | Home > Technical (L322) > Exterior Mirror Dip when reversing |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964      |
 Mine don't.
|  23rd Nov 2011 11:00am |
| nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2080      | It only works on the near side | ||
|  23rd Nov 2011 11:01am |
 I know. | ||
|  23rd Nov 2011 11:05am |
|  23rd Nov 2011 11:29am |
 According to the manual, the mirror dip will only work when the mirror select switch is set to the drivers side. But mine doesn't work regardless of where the mirror select switch is set! | ||
|  23rd Nov 2011 11:31am |
| Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537    | Is it possible to adjust the angle of dip? Mine goes almost horizontal! The old P38 was much better in this respect! | ||
|  23rd Nov 2011 12:36pm |
| Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964      | Cappo: yes that's simple - just select reverse, adjust and store against the number button you are using for seats etc. | ||
|  23rd Nov 2011 5:30pm |
| RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597      | Simes, not that it helps, but I can confirm what you say in that the mirror selector does have to be switched to the 'adjust the drivers side mirror' position else the near side one doesn't dip when reverse is selected. Bit dumb really, you'd think it would just automatically override the mirror setup switch in the first place! Steve
|  26th Nov 2011 11:53pm |
 Hmmm, doesn't seem to work.....   | ||
|  27th Nov 2011 12:21am |
| fraserl322 Member Since: 03 Aug 2011 Location: Melbourne, Australia Posts: 2    | 2002 hse here, no mirror dip, and the passenger mirror seems to have no memory, the drivers side remembers settings, but the passenger side just stays where I move it to.
|  24th May 2012 11:14pm |
| 5IMON Member Since: 27 Nov 2011 Location: London Posts: 165  | Ive had two range rovers and both of them have had wing mirror problems , just my 2 cents | ||
|  24th May 2012 11:33pm |
| T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187      | My passenger mirror goes haywire when reversing - to the extent if I forget to stop it from doing the reverse adjust, by having the adjust switch set to passger, I have to get my wife to manually pull it back in through the window.
|  25th May 2012 12:09pm |
| RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648      |
 I have had 4 or the previous 3 all had mirror problems so watch this space!!   FYI the 2012MY FFRR dips BOTH mirrors.  If you have nothing nice to say,say nothing at all. | ||
|  25th May 2012 12:25pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | The mirror will only dip if the car has memory seats fitted.
|  25th May 2012 5:56pm |
| Posting Rules
