Home > Technical (L322) > Exterior Mirror Dip when reversing
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Mine don't.
Followed the instructions in the manual - mirror select set to drivers side - into reverse - nothing. Car in reverse, set the mirror to a dipped position manually and save it - nothing else happens - it just stays there sullenly...
Any thoughts? Could it be disabled? If it is, can I re-enable it?
Post #93888 23rd Nov 2011 12:00pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
It only works on the near side
Post #93889 23rd Nov 2011 12:01pm
Simes
I know.
Post #93891 23rd Nov 2011 12:05pm
nbunney
Re: Exterior Mirror Dip when reversing
Post #93892 23rd Nov 2011 12:29pm
Simes
nbunney wrote:
According to the manual, the mirror dip will only work when the mirror select switch is set to the drivers side. But mine doesn't work regardless of where the mirror select switch is set!
Post #93893 23rd Nov 2011 12:31pm
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Is it possible to adjust the angle of dip? Mine goes almost horizontal! The old P38 was much better in this respect!
Post #93905 23rd Nov 2011 1:36pm
Simes
Cappo: yes that's simple - just select reverse, adjust and store against the number button you are using for seats etc.
Post #93996 23rd Nov 2011 6:30pm
Roystonh
Hi
My new 2011 model has just developed wonky mirrors too - they dipped great but now have stopped moving down, something for the first service list. Not worried though, love the car :@) 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #94684 26th Nov 2011 11:40pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Simes, not that it helps, but I can confirm what you say in that the mirror selector does have to be switched to the 'adjust the drivers side mirror' position else the near side one doesn't dip when reverse is selected. Bit dumb really, you'd think it would just automatically override the mirror setup switch in the first place! Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #94689 27th Nov 2011 12:53am
Cappo
Hmmm, doesn't seem to work..... Confused
Post #94694 27th Nov 2011 1:21am
fraserl322
Australia
2002 hse here, no mirror dip, and the passenger mirror seems to have no memory, the drivers side remembers settings, but the passenger side just stays where I move it to.
Any suggestions?
Ta,
Fraser
Post #123553 25th May 2012 12:14am
5IMON
Ive had two range rovers and both of them have had wing mirror problems , just my 2 cents
Post #123556 25th May 2012 12:33am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
My passenger mirror goes haywire when reversing - to the extent if I forget to stop it from doing the reverse adjust, by having the adjust switch set to passger, I have to get my wife to manually pull it back in through the window.
Potentiometer issue according to IIDTool....
Post #123616 25th May 2012 1:09pm
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
I have had 4 or the previous 3 all had mirror problems so watch this space!! Confused
FYI the 2012MY FFRR dips BOTH mirrors. Thumbs Up If you have nothing nice to say,say nothing at all.
Post #123618 25th May 2012 1:25pm
mjdronfield
The mirror will only dip if the car has memory seats fitted.
I assume it was working before, as oppose to it never having worked ?
So if you have an HSE or something without memory seats the function won't be there.
Sorry if you've had your car for 5 years and know it inside out - just trying to cover all bases. Smile
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #123653 25th May 2012 6:56pm
